Ls1 header install, rattle noise
Old Nov 21, 2017 | 03:24 PM
Ichurch's Avatar
Default Ls1 header install, rattle noise
First post on this site, but this noise has been bugging the crap out of me. Ive had 1-7/8 LT headers and 3 inch off road y installed a little while now on my 2000 ss. They sound great when the rpms are right, although right when accelerating especially up to highway speeds there is a ridiculously loud rattle type noise. It happens between 2-2500 rpm under load, it wont do it while in neutral. Ive checked to see of maybe if the heat shield was touching but couldnt see anything. Im going to replace the 02 sensors since they were rattling a bit, but i cant for the life of me figure out what this very loud noise is. I describe it as a tinny rattle noise or tick, more of a rattle though. Anyone else experience this before or solve it? thanks!
Old Nov 21, 2017 | 03:36 PM
Look for anything that would be in the way in the direction the engine torques over to. It has to be hitting something.
Old Nov 21, 2017 | 05:32 PM
Jtm2085's Avatar
^yep. Check the header/k member, y pipe and floor board
Old Nov 21, 2017 | 06:20 PM
2ToeRacing's Avatar
^^^^what he said^^^^^^
Old Nov 22, 2017 | 12:43 PM
computerz's Avatar
If it's not something physically vibrating, could it instead be ignition knock? Was your car tuned?
Old Nov 22, 2017 | 01:33 PM
00pooterSS's Avatar
How old are the engine mounts? If they aren't pretty fresh it might be that when the engine torques/rotates a little under acceleration something is rolling over and hitting something. Lots of header and exhaust fitment/noise issues are from worn mounts. There's a couple ways to check them, if they aren't fairly new do not assume they are good, this bites a lot of people.
A sound clip would be helpful too.
Also, are you sure it isn't an exhaust leak? Exhaust leaks can sound like lifter tick etc and some people describe the noise differently.
Old Nov 28, 2017 | 01:27 AM
Ichurch's Avatar
sorry been busy with college, but i have not changed engine mounts since owning the car. Also at some point soon i will have it tuned. i can try and get a sound clip although i think id have to link it to youtube or something since this site doesnt allow for very long video clips. Dont think its an exhaust leak, going to try and get it checked out a bit more over winter break on a lift.
Old Nov 28, 2017 | 11:52 AM
Even if the mounts are good, a header a little too close to something will vibrate against it and rattle enough to drive you nuts.
Old Nov 28, 2017 | 02:05 PM
DANOZ28's Avatar
my torque arm use to rattle off my driveshaft safety loop. took a long time to figure out. goodluck! doublecheck your trans mount isnt broken
Old Nov 28, 2017 | 10:30 PM
wannafbody's Avatar
I have an occasional rattle noise which I think is the I pipe rubbing the heat shield as it crosses over the rear axle.
