True duals over the axel
Old Feb 7, 2018 | 09:53 PM
Philhippy45's Avatar
Default True duals over the axel
Ok so i have a question everyone. I have a 2000 Camaro z28 ls1 that I'm currently building 243 heads for as well as other things. So my question i have is will the speed engineering or tsp true duals 3" over the axel be louder then my current setup which is 1" 7/8" pacesetter longtubes tsp 3" ory and a loud mouth 1. Or will it be quite. And if I cut the mufflers/resonators or whatever they are im assuming mufflers off will it make it louder then the setup I have now. I want to have a dual exhaust but still have it as loud if not louder. So what do you guys think?
Old Feb 7, 2018 | 09:56 PM
cjruot's Avatar
If you want loud, just run the TSP true duals how they were designed... just short of the axle... I run Pacesetters and the TSP TDs and it's deff loud enough... I'm old enough now, I might quiet it down a bit... hahaha
Old Feb 7, 2018 | 09:57 PM
98CayenneT/A's Avatar
Add a electric cutout
Old Feb 7, 2018 | 09:59 PM
haha never to old to have loud cars lol. Im 25 im only building mine to go to car shows with my dad he has a 72 Camaro 454 lol. So i know loud. But couldn't I just cut the mufflers out? Wouldn't it be the same just longer? Plus I like rear exit exhaust call me old fashion but I do. Im assuming it would be the same especially with the stuff im adding to the car like heads intake and cam
Old Feb 7, 2018 | 10:08 PM
cjruot's Avatar
In theory it should be the same... Go for it man... get the sawzall after it and see how it sounds... worst case, you'll be welding it back together... hahaha
Old Feb 7, 2018 | 10:09 PM
eh I dont mind welding lol worse comes to worse I'll just put nice tips on it like the single tips for some reason I dont like duals.
Old Feb 7, 2018 | 10:11 PM
Electric cutout to open for car shows or track and close for cruising around when needed.
Old Feb 7, 2018 | 10:14 PM
HCI2000SS's Avatar
Like mentioned above if you want loud just get a cutout. It's gonna be cheaper and louder than switching up your exhaust to something else. So basically a win win
Old Feb 8, 2018 | 07:24 PM
_JB_'s Avatar
I have Speed's true duals, it's ******* loud but sounds great. I'm thinking if you remove the LM1 it's still going to be raspy due to the y-pipe.
Old Feb 8, 2018 | 11:03 PM
is that the over the axel or dumps? And im gettimg rid of the y and lm1 I have the speed enginering over the axel and im thinking about removing the muffler and putting a straight pieces of pipe in there which essentially shpuld be the same as the dumped version just with the tips out the back which i like. Basically a dual exhaust lm1 lol
Old Feb 10, 2018 | 03:39 PM
_JB_'s Avatar
Mine are over the axle.
Old Feb 12, 2018 | 12:23 PM
blkbird's Avatar
Ive got the over the axle duals from speed engineering. Its pretty damn loud and has a good amount of drone in the cab as well. Somewhat quiet at idle but a totally different story at WOT...... Ive been through quite a bit of systems. Ive had custom true duals dumped with moroso spiral flows. Loved the sound of that setup. Them went with the LM1 with a moroso instead of the resonator. Bit quieter than the duals. Now I'm with the current set up.
Old Feb 12, 2018 | 05:15 PM
LaBLKv6Z's Avatar
It's louder and drones more but sounds really good at WOT. I couldn't take the drone any more so I installed some 5" round magnaflow mufflers before the axle and dumped them.
