so why are my headers glowing UPDATE!!!!
2000 camaro, stock bottom end, cam in the upper 230s, ls6 intake, old dynatech headers into a 3 inch y, 4 inch single dumped. 241 heads. that was the old setup. stock maf
new setup is the same as above, but now a fast 90, nick williams tb, 36lb densos, ported 799s. the tuner redid the tune to a basically a mail order to get it it running.
so i have done 3 8 mile trips keeping the rpms under 2500, all do ok. the car likes to stop taking throttle and u have to let off and get back on it to fix this. surging is decent for a base tune. idled around 950 and stays very steady. doesn't go up or down. occasionally the idles like to hang for a little just before i completely stopped. id like to say since it idles fine i have no leaks. didn't notice headers glowing cause i always drove in daylight. now heres where it changes
i just got done taking it to the shop to get inspected tomorrow. its nighttime. in order to pass inspection, i have to remove the 4 inch muffler, and add my cheater exhaust which goes from a 4 inch to a 2.5 inch, then into a 2.5 inch dynomax buller muffler. so obviously we are semi restricted. that was the only change i made. when i started the car it idled at 1200. then i begin driving and the car starts driving itself. if i push in the clutch while moving the rpms stay right below 2000. when i approach to a stop it idles at 2000, but a simple tap of the throttle and it slowly returns to 950 and idles perfect after about 8-10 seconds. i drove the 3.5 miles on the highway at around 60 mph. then drove 1.5 miles and hit 2 redlights on a 35 mph road. i get to the shop and pop the hood with the car running . im like man it feels hot. i look and the headers on both sides cylinders 5,6,7,8 are a tad orange/pinkish. very faint but can be seen. the light was kinda on the front 4 cylinders so its tough to tell if those we colored as well. my dummy coolant gauge was a hair above 210, its usually a needle width below 210.
could it be a combo of terrible exhaust flow and the shitty base tune? i torqued the intake like u would heads, from inside to out in like 6 different passes until it started taking some effort with the 1/4 inch drive. i used new gaskets, the map i used a new grommet, and slapped a ton of black rtv. its pretty good with minimal flex. i will put new exhaust on tomorrow after inspection, and put the correct exhaust on and redrive it but what thoughts do you guys have?
That your exhaust change seems to have induced high idle speed, I can see this being the cause.
P0122 TPS circuit low input
P0507 Idle air control system RPM high
p0121 TPS circuit range.
now theres no way the low input and range codes came within the 30 seconds the tis was unplugged. so i assume those codes were just about to come on but now that i hopefully found the culprit i have to get a TPS before my tune which is tomorrow so thankfully we may have gotten this. it sucks i sold my old tb with good sensors on it 3 months ago. off to the dealer tomorrow i guess
unplug it.
Turn key on for like 30 seconds.
Turn key off and let it sit for a few seconds
Plug TPS back in.
Then start car.
maybe that helps.
I get how frustrating it can be, my tuner just finally figured out my idle probably today and I am so relieved.
After that you (or your tuner) will want to throw a meter on the TPS and see what voltage you are getting at idle. It should be around 0.5V. Mine was up at .744 and it caused all sorts of idle issues since the ecm is seeing that as a few % open throttle position. I believe it needs to be under 0.6V at idle for the ecm to think the car is at "idle" aka 0% throttle.
