Anyway to get more power?
Old Jul 29, 2018 | 11:38 PM
LS_Power's Avatar
Default Anyway to get more power?
Just wondering if there’s anyway to get a little Moreno power out of my LS1? So far the mods are a mild cam, LS6 intake, 1 3/4 headers, PRC 2.5 862 heads, MSD spark plug wires, upgraded injectors. Just trying to see if I can squeeze anymore power out of my car? I don’t want to go forced induction trying to stay N/A. I was thinking about getting a true dual system and ditching the Y pipe. I was also thinking about getting a FAST 92 intake and throttle body. If you have anymore opinions on what I could do please feel free to give me some suggestions!
Old Jul 30, 2018 | 12:03 AM
Which cam do you now have? State duration for intake and exhaust @ .050"lift., total lift, and LSA.
Old Jul 30, 2018 | 12:14 AM
LS_Power's Avatar
Originally Posted by g atsma
which cam do you now have? State duration for intake and exhaust @ .050"lift., total lift, and lsa.
218/227 .600/.600 112+2 lsa
Old Jul 30, 2018 | 12:16 AM
98CayenneT/A's Avatar
A4 or M6 ?
Bigger cam, bigger intake, bigger headers, better flowing exhaust will get ya some good gains. Flow master y pipe merger at least.
Old Jul 30, 2018 | 12:22 AM
LS_Power's Avatar
Originally Posted by 98CayenneT/A
A4 or M6 ?
A4. Couldn’t get a bigger cam because of the stock stall. Thinking about getting a 3600 stall, FAST 92/92 and true duals. But I love the way my Trans is at the moment. Shifts firm and no sign of age really. Just kinda been scared to do stuff to the trans because it would be awhile before I get a built one of if blow the stock one.
Old Jul 30, 2018 | 12:31 AM
A converter is not going to be any harder on your transmission.
I would not do a thing until you add a converter. Adding something like a yank ss 3600 to your current setup will feel like you added literally 100 whp due to MUCH better shift extensions.
Old Jul 30, 2018 | 12:47 AM
LS_Power's Avatar
worth doing a transgo shift kit when I do the converter too?
Old Jul 30, 2018 | 01:15 AM
Absolutely, I rebuild my own transmission and run the sonnax performance pack but either will benefit you.
Also think about adding the sonnax 2-3 shift valve. It keeps the over run clutches on when the shifter is in D3.
This helps support the forward sprag assembly and allows more stable fluid pressure to the 3-4 clutch pack.
Old Jul 30, 2018 | 03:46 AM
HCI2000SS's Avatar
A good aftermarket stall is going to do more for you than anything else
Old Jul 30, 2018 | 06:08 AM
Tuskyz28's Avatar
A better stall
A better set of heads like TFS
A new cam to match those heads
A true dual exhaust would also help
Old Jul 30, 2018 | 06:16 AM
fst100's Avatar
like mentioned above as well as possibly an underdrive pulley to squeeze out some hp and an electric waterpump. if you're planning on racing it then do an a/c delete, suspension mods and weight reduction to get the max effort on the power to weight ratio.
Old Jul 30, 2018 | 09:26 AM
LS_Power's Avatar
Any recommendations on a stall speed that’ll go good with a 218/227 cam? Thinking 3200 or 3600
Old Jul 30, 2018 | 09:29 AM
fst100's Avatar
either a 3600 or 3800. I had a 3200 in my firebird and I felt it still wasn't enough. I got a 3600 in my Camaro now and it feels/pulls pretty good. wont know if this converter I bought from another local member will be worth it or not til I take it to the track.
Old Jul 30, 2018 | 12:46 PM
00pooterSS's Avatar
The stall will give the most for the money at this point.
Since you already have a decent cam and heads, if you want to do something for the motor get a better intake ( a FAST), it's getting fairly choked by that LS6 now.
And make sure the exhaust is good as can be. A single 3" can do the trick if you have a great merge. The dual 3" to single 4" with a cutout is a hell of an exhaust setup to for low $$. Or go to a true dual.
Old Jul 30, 2018 | 01:24 PM
LS_Power's Avatar
Thanks for the replies guys. Pretty sure I’m gonna look into a 3600 stall with a shift kit and a Trans cooler, then probably get some true duals to finish it off.
Old Jul 30, 2018 | 04:41 PM
00pooterSS's Avatar
Don't cheap out on the stall, the cheaper ones are less efficient, which means less power making it to the tires and more being wasted and also creating more heat in the fluid.
I'd recommend a Yank SS3600, or a circle D stall.
Oh if you don't have drag radials you're gonna need them bad once you get a stall.
Old Jul 31, 2018 | 12:07 AM
LS_Power's Avatar
im all good on tires I just got some Micky Thompson’s ET street SS’s just trying to get a little more out of it
Old Jul 31, 2018 | 12:10 AM
A converter will get ya a lot more out of it.
How high do you spin your motor ?
Performance wise a PT 4000 would yield you the best gains.
Old Jul 31, 2018 | 12:40 PM
LS_Power's Avatar
set to shift at 6400. Just looking to get a good driveable stall. It’ll be drivin on the street a lot
Old Jul 31, 2018 | 12:52 PM
00pooterSS's Avatar
From what I remember a SS series Yank converter would be better than the PT for your usage then. A SS3600 is plenty of converter. The PT4000 would likely annoy you if you do a lot of street driving.
