Little injector help.
I'm running the LS6 intake set up but my injectors have been sitting for years. I was wondering what a good replacement injector would be. I believe these are 28lb stock which I imagine is plenty but any input is welcome.
I like GM parts but if there's a reputable aftermarket injector i wouldn't mind a set of those.
or maybe a mail-order injector service? I can't find anything non-diesel here locally
I run high concentrations of Chevron Techron fuel system cleanser in small amounts of fuel to finish this cleaning job after this initial effort.
Rick
Rick
Any thoughts on these?
https://www.texas-speed.com/p-2346-r...-injector.aspx
Is 37# too big for about 400hp from a 5.3?
It will be tuned for sure,
Also I saw people using 30# SVO injectors (dated posts), is this still a thing?
https://www.jegs.com/i/Accel/110/150830/10002/-1
Honestly though, I bought a set of remanufactured ones for a 2003 Buick Regal for $50.00 on eBay. They work great. I believe they were Delphi's if I'm not mistaken.
Meticulously hand ported and polished 799s flowed to 325 cfm and milled .030 with carefully reworked ccs and 2.02s with one hell of a valve job... Then Ed Curtis cut me a cam to match. Tracey Scott will be tuning it day in and day out for a little bit.
So 400 ish. I'm more going for the calculated, hand-crafted by different level people that actually take their time and care (Michael Bennett (custom hand porting) Ed Curtis (custom camshaft), and Tracey Scott (At home, on street, and on dyno full service all season tuning) by the way) to create a very clean, smooth, yet powerful, pretty damn efficient little Sonoma that will do everything I want it to do.
all that aside though, should I get these ls6 28's cleaned and flowed and sealed or, if not, what brand injectors do y'all have experience with being reliable and smooth more so than yee haw hot rod status.
I have a small shaft and a mediocre career with a weak little truck I'm building.. boo hoo for me.
My wife is hot though.
But I dont care enough about life to be a snob. sad but true...
I literally just want some new injectors
The stock truck injectors max out at something around 400 at the crank. Details vary but somewhere in there. Biggest thing you're going to run into is, the truck injectors are MUCH shorter than most others, like about ¾"; if your fuel rail setup isn't specifically for a truck, they won't work, without adapters. (not sure what options FAST offers in this regard...) 30 lb isn't much of a change, probably a good choice for a 5.3, you're never going to exceed that without boost or something.
