Issues installing chrs1313
Old Aug 19, 2018 | 05:48 PM
Floorman279's Avatar
Default Issues installing chrs1313
Top radius contacting radiator
Bottom part touching radiator support base
This shows how much further front i must go. I need to get tp the rust line
got this used off of here.
Though
Old Aug 19, 2018 | 05:52 PM
Got this used off of her. Non ac version, thought all i had to do was remove old setup and cut out hood latch support. First i had to bend and hammer down the bottom Ear where the hood support bolts to the car. Then i had to rip out both plastic pieces, then i had to bend the bottom lip on the 1313, the little air dam piece was contacting the front bumper and wouldnt go past. Now i get it in place and the airbox/radiator holder piece wont go forward the half inch i need it to go......wtf, it looks like the top radius is too high or something
Old Aug 20, 2018 | 08:34 AM
01ssreda4's Avatar
Yeah the non-ac is a big SOB to cram down in there.
Old Aug 20, 2018 | 06:09 PM
yea so how do i make it fit ......its basically fully seated on the top rad support but won't mover towards the front anymore
Old Aug 20, 2018 | 09:11 PM
hopefully i dont hear crickets on this too long....not trying to buy another intake
Old Aug 20, 2018 | 09:41 PM
i went out and used a lot of force and i could probably get the bolts to line up but i would just rather not.......i could drill new holes in my air box base so i could bolt it to the car, or i can start grinding on my rad support
Old Aug 21, 2018 | 10:27 AM
01ssreda4's Avatar
My upper was not cut, and Im pretty sure I had to hold the top plate and stick the bolts in at the same time
Old Aug 21, 2018 | 01:46 PM
I can get the holes to lignore up with a lit of force, but it flexes the radiator a good bit
Old Aug 21, 2018 | 01:47 PM
Not sure if beating the hell out of the intake will work or not
Old Aug 21, 2018 | 01:49 PM
What if I put it in a vise near that top radius? Should pancake it a good bit......which may be necessary anyway when I get an lt1 radiator
Old Aug 23, 2018 | 09:21 PM
ended up hitting it with a hammer on the headlight side of the intake....got it tightened up and it sits about 3/8" away from the rad
