02 problem
Old Aug 20, 2018 | 07:07 PM
Sabes's Avatar
Default 02 problem
So ive been having parasitic draw killing my battery very quickly, come to find my 02 sensors are very warm to touch. So i cut the switched ignition to no avail, still hot after a few days. Why else would they be heating up? Its a 99 or 00 block, harness and pcm.
I will mention i wires everything myself, it runs otherwise except it seems to run rich. I assume this may be the issue for that also, seeing the 02s are hot but the block is cold.
Old Aug 20, 2018 | 09:19 PM
You might want to make sure the 02 sensors ARE on a switched circuit! Mistakes DO happen...
Old Aug 21, 2018 | 04:31 PM
8.Lug's Avatar
The heating circuit for the o2 sensors are only supposed to be on when they are cold. They are controlled by the PCM. They’re not supposed to be on a switched circuit, they’re supposed to be on their own circuit right from the PCM - nothing else. You’ve probably overheated them and ruined them. Redo your wiring properly and buy new sensors.
Old Aug 21, 2018 | 05:47 PM
Sabes's Avatar
The pcm doesnt do that?
Old Aug 21, 2018 | 07:21 PM
Anything that turns something off and on IS a switched circuit, whether it's the PCM or manually done. In this case SOMETHING kept them on and likely burned them out as Lugnut said.
Old Aug 21, 2018 | 08:52 PM
Sabes's Avatar
After i got G Atsmas' mssg I went and double checked a diagram i used. So my understanding is this is "ign. on, heated cuircut on" "ign. off, heated cuircut off". However your saying this should be temporarily on, could the ground be switched? Im pretty sure i grounded to chassis or block.
Old Aug 21, 2018 | 08:54 PM
Sabes's Avatar
The only other possibility seems to be switched ground assuming the heated circuit doesnt ground through the exhaust pipe.
Old Aug 21, 2018 | 09:10 PM
Sabes's Avatar
This one shows a pin 63 i may have missed it also attaches to engime coolant temp. Could that be my problem if i missed it?
Old Aug 22, 2018 | 10:40 AM
bammax's Avatar
Black is ground and pink is hot which powers the sensors. Purple and tan are the signals coming back from the sensors. You want to look at the power distribution schematic to see if the pink is run through a relay (which I'm pretty sure it is). The relay will only send power to the sensors if it's switched by another sensor (most likely a pcm signal or a temp sensor directly).
Old Aug 23, 2018 | 01:41 AM
8.Lug's Avatar
The PCM controls almost everything by the grounds. The coils, the injectors, the heater circuits for the O2 sensors - I don't know what that diagram is but the PCM needs to monitor the heater circuits. You should be getting codes with them connected directly to chassis ground.
