Intake differences
I have a 6.0, 243 heads, new GM hot cam and shorty headers for my
daily driven S10, not a track truck.
Thanks, David
link to the thread with details
https://ls1tech.com/forums/generatio...rt-more-2.html
Edit- What happened to the ported Dorman LS2. Porting did NOTHING for it! And in some places it's WORSE!
So I was wondering if it is worth the investment to buy a dorman ls2 intake for
for my daily driven S10.
Thanks for the help
There can be a little variation intake to intake or cylinder head to cylinder head etc.
See post 261 & post 280 for details in the thread below.
https://ls1tech.com/forums/generatio...t-more-14.html
This is the flow data for for the newer manufacturer Dorman LS2. One side of the intake was not ported and the other side was ported. The porting improved the high lift flow.
What's interesting is the Dorman LS2, the ported DLS2, and the LS6 are all so close it would not be worth it to change from one to either of the others if you own one of them.
If one has an LS6 intake, $350 for the 90mm snout is a good upgrade in my opinion. Add ~$125 for a WARR 92 mm TB and for $475 it's a decent upgrade in many cases. Getting good drive ability out of the LS6 90mm is also easier than with some of the other intakes. That's based on my experience trying to get an LSXRT with a 102mm TB to drive well on a 383 LS1 stroker and also testing fast LSX 90/92 on the same set up. The car was my 91 RS with a drive by throttle cable with 411 / 2002 LS1 Camaro PCM. For a high rpm set up say 6800 -7000+ rpm, I'd pick a different intake probably the Fast LSX 90/92 if cable drive TB.
Dyno testing and track testing of course is better than flow testing as flow testing is a simple basic test.
I have found the "plastic" intake manifolds KEEP the air COOLER thus a more dense charge of air into the cylinder.
I have found the Aluminum intake manifolds ADD HEAT to the air thus a less dense charge of air into the cylinder.
There should be a study, here at LS-1 Tech, of the port air temperature increase for each referenced intake manifold ?
Lance
