5.3 valley cover question
https://www.cfrperformance.com/ALUMI...z-8010-pbk.htm
Will this work for filling oil for the gen3 5.3?
Funny you posted this now as I'm looking for the same thing but wasn't planning to run the hi-ram the only valve covers I've found that cover the coils AND have an oil fill are the Billet Specialties but they're over $1000 a set.
I want the look but I guess I'll have to relocate the coils to get it done.
Other downside....have to pull a valve cover to add oil. Not a huge deal but still....
https://www.summitracing.com/parts/bsp-95037
try this out see what you think https://www.cfrperformance.com/HZ_80...z-8000-pbk.htm
this was a perfec solution for what i want to do. plan on running script valve covers. i'll probably also make a small notch in the back of the adapter for the coil wires to tuck them back behind the engine so you can't see the wires either.
https://www.summitracing.com/parts/sum-440690?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-summit-racing&gclid=CjwKCAjwio3dBRAqEiwAHWsNVQjkI9obN6i59 IhekrsuWrzv8FwTorhDkoMb1LOUBi4Uyoq5a46wlhoCCVsQAvD _BwE
I don't see any reason these couldn't have an oil fill cap added to them just like the Billet Specialties units.
https://www.summitracing.com/parts/a...-vcc/overview/
The video of the install... https://www.cfrperformance.com/HZ_80...z-8000-pol.htm
With mine being turbocharged and having a catch can, I think I'll end up with a setup similar to what you described.
