WS6 misfire/hard start
And check for fuel pressure drop when you turn the key off it should drop real slow and then kinda hang out. If it drops fast and down to 0 the check valve in the pump is bad and will cause long/hard or no start issues. Also of course make sure it is making proper pressure.
Did you try the cam sensor? Cam sensor can cause your issues. Check the wiring carefully too. I've seen some bare harnesses at the connector.
Also check the grounds on the back of the driver cylinder head, that's a common source of issues.
So it goes to **** when it goes to closed loop. That means that most likely one of or more than one of the sensors not used in open loop is acting up and when it starts reading that sensor it goes to ****.
Again, seen that before with 02 sensors.
