2nd attempt at posting about needing help with Spark Plug Wires
I am seeking some help with Spark Plug Wires.
I am concerned with performance as much as I am with Aesthetics. So I have been looking for the Taylor Spiro Pro Wires in Lime Green for an LS1-LS family of engines and they do not seem to make it in this particular color. I was wondering if anyone else had done a universal set either the 8 MM or 10.4 MM wire sets and cut them and crimped them by themselves or do you all just buy whatever is available over the counter and just deal with what you can get your hands on? I like the lime green as a contrast color. I am an airbrush artist as well as other things, and when I do a project, I worry about the aesthetics as much as I do the end results with performance.
So my main question is, Can a 10.4 MM Taylor wire set be used on an LS1/LS engine family? Or do the universal sets not come with the correct boot setups to complete this task?
I plan to do quite a bit of airbrushing on the underside of the hood and on various parts and pieces under the hood, fabricate or purchase covers for things, a strut tower brace and things are perfect candidates to airbrush artwork on prior to installing them. While I have an extensive history of doing corvettes and have a side business doing C3 and some C2 corvette restorations and part sales from parting out many C3 vettes, and have a few trans ams of various years, and other cars for sale for projects, or parts cars or restored cars (have 7 big block corvettes in line to be restored at the moment, 4 speeds, convertibles, automatics, T Top Coupes etc. with various options and such.
I just picked up this white WS6 with a 6 speed in white as a driver and wish to spruce it up a bit because most airbrush artists like myself usually can not keep their hands to themselves and will airbrush just about anything they can get their hands on.
Any help or advice would be greatly appreciated.
Thank you all appreciate your time.
Jennifur
Jennifur
https://ls1tech.com/forums/generatio...look-good.html
Burkhart or MWC front bumper brace $250
Michigan Motorsports Coil Pack Relocation Kit for LS1 LS6 LSX Stainless Steel Brackets and Harness $112.00
Jaz Products 602-025-01 Black Radiator Recovery Tank $31.22
MSD 25 ft spark wire 34019 $52.17
MSD 45 deg boots 3304 $9.59
MSD 90 deg boots 8850 $21.33
MSD STRIPPER-CRIMPER MINI 3503 $8.69
Spark plug heat guards 40300 $42.99
The reason for the front bumper brace is so that you can mount the Jaz coolant overflow tank to it as the stock overflow tank needs to be removed to perform this mod since it is in the way of where the coil packs will mount on the passenger side frame rail.
More info on this mod here:
https://ls1tech.com/forums/generatio...tion-kits.html
But to answer your question, you can certainly make the plug wires any length you want using products from MSD.
Wouldn't it be something to run 8 second pass in a car that you drove to the track, then enter the car into the car show at the track event right after the pass and win best in show? I guess with enough $$ and seat time, anything is possible. I'm still trying to figure the 8 second pass thing out first....
https://www.ebay.com/itm/Heat-Shrink...-/263585291764
My best recommendation is to get some neon green tech flex and put that on the wire
https://www.techflex.com/general-pur...part=PTN0.50NG
It's easy to put on and is high quality stuff. You push it together like a chinese finger trap to expand it then release it and it goes down in size. Should be real easy to make it work on a set of wires.
I would call Taylor and ask them. Many times manufacturers don't put every little part they make on their web site.
https://forums.corral.net/forums/5-0...lug-wires.html
https://forums.corral.net/forums/roa...torsports.html
If you want lime green or some other kind of funky color you can paint the wires with plasti-dip. That stuff is flexible and should hold on and not crack when the wires are bent.
I made my own wires uses MSD components. For all I know, MSD stuff may be no better than Taylor, but it seemed to have a much better reputation when I was I shopping for wires.
Does Granatelli sell bulk wire, boots etc.?
