'00 SS Gauge Lights
The problem is periodically when I drive my car three dash lights pop up on my gauge cluster at once, those lights being:
The traction control "ASR" light
Emergency brake "BRAKE" light
Lastly the ABS "ABS INOP" light
I've tried some trouble shooting and have seen that possibly the alternator could be the culprit and also a wheel speed sensor.
I would like to know if anyone has experienced this and if there is a straight forward fix without dumping a lot of money at BS trying to fix it.
Other than the 3 lights my car runs and drives fine.
With that being said my buddy is a manager at a shop and has a code scanner and the one code that pops up is a "P1637 Generator L-terminal circuit" so with some searching on that I'm leaning towards the alternator even though it rarely dips below 13v.
Any and all help is appreciated!
Questions: Is there a diagram that will show me the location of the connections so I have a good place to start?
Also is there a particular shop or place that has a scanner that can read the ABS codes? I've done some searching with no luck on that part.
Thanks in advance.
Thanks in advance.
Again, thanks for all of the recommendations! Still trying to sort through it.
I've done a lot of research and long story short I took my EBCM out to do a little soldering. Well I was short on time and when I seen that the cover wouldn't come off without a little cutting and prying I said F it for now since it was my nephews birthday and had work the next day. I put it back in and the lights have been off for over a month now (90 mile round trip for work) and everything has been working perfectly. Maybe I scared it fixed? Maybe it knew I was about to solder the F out of it? IDK and don't care unless the lights come back on haha. So for you guys still wondering the good ole take out and put back in did it for me... for now.
