Hole in oil pan?
When I was taking this engine apart,I found some metal in the oil. Nothing in the engine was broken. I found this when I had the oil pan cleaned. Is that hole supposed to be there?
No oil leaked anywhere.
Look at the bottom pic. The hole at the 9 o'clock position is what I'm concerned with. It looks like it's half drilled for a reason, but then if you look at the right side of that hole another piece of missing. When I looked at it, it looked like the same material that I found in the oil.
When I looked at it, it looks like more of that material from around that hole has broken away. I saw in another thread last night that this hole is supposed to be there, but if you look at the shape, on the right side of that hole, it looks like a piece of that side broke off.
Like it was supposed to be a half circle.
I found a couple small pieces of metal in the oil. And they really really look like they'd come from this circle opening up a little.
https://ls1tech.com/forums/generatio...n-cracked.html
Today's for the help fellas!
