Engine Dies please HELP!
Old Feb 19, 2020 | 11:59 AM
Traceyl2692's Avatar
Default Engine Dies please HELP!
Recently done an engine swap from 4.8 to 6.0, only swapped bottom end, reused 799s intake etc.. retuned and it runs great! But ive found if im idling and stomp the accelerator when the engines rpms come back down the engine dies, it will start back up and idle again.. but if I stomp the accelerator again, engine dies again! Can anyone shed some light on this issue? Thanks
Old Feb 19, 2020 | 03:21 PM
00cls1camaross's Avatar
Sounds like a tuning issue. Have you talked to your tuner?
Old Feb 19, 2020 | 07:47 PM
I have not, my tuner is 3 hours away, was hoping that someone else had experienced this problem and could give me an idea other than tune because it runs really well other than this issue
Old Feb 19, 2020 | 08:29 PM
dreadpirateroberts's Avatar
What throttle body are you using? Aftermarket or oem? DBW or cable?
Old Feb 20, 2020 | 08:02 AM
Darth_V8r's Avatar
Moderator
Its a tune issue. Likely just base airflow is a touch low. Only fix is in the tune. If you have HPTuners you can fix it via email vs driving
Old Feb 20, 2020 | 09:39 AM
senicalj4579's Avatar
My car used to do that sort of thing. I had to do a IAC valve relearn every once in a while and that got the car on track. Something probably could of been changed in the tune also.
Old Feb 20, 2020 | 07:02 PM
Im using oem throttle body, and its DBW
Old Feb 20, 2020 | 07:48 PM
If you are running the same tune as the 4.8, i would agree with darth. You just need the idle tuned again.
Old Feb 20, 2020 | 07:58 PM
01CamaroSSTx's Avatar
How do you correct idle recovery with the software?
Old Feb 20, 2020 | 08:13 PM
Darth_V8r's Avatar
Moderator
By increasing base idle airflow
Old Feb 20, 2020 | 09:05 PM
Its not the same tune at all.it has been retuned since the swap.
Old Feb 20, 2020 | 09:15 PM
SLP IROC-Z's Avatar
doesnt mean the tune is correct
