Plug Wires For Coil Relocation
Old Mar 6, 2020 | 02:47 PM
blsnelling's Avatar
Default Plug Wires For Coil Relocation
What would be a good choice of plug wires to use when doing my coil relocation brackets? I understand the plug ends for 93-97 Camaro LT1 engines work? What's a good brand? PN? Link? Red would be nice. I THINK I'm going to mount them on the bottom side of the cowl, but am open to suggestions.
Old Mar 7, 2020 | 02:11 PM
blsnelling's Avatar
I'm going with the following.
Wire - MSD 34019
Straight plug boots - MSD 3301
45* coil ends - MSD 33048
90* coil ends are MSD 3331
90* plug ends are MSD 3311
Old Mar 7, 2020 | 06:55 PM
91LS1T56's Avatar
I like the way the Taylors look. I assembled them myself to get what I wanted. Unfortunately I have a problem removing them and from time to time the clip stays on the plug. In order to not be stuck or have to wait I purchased extra. I picked up a universal V8 set (79253) and a set of LS1 coil boots/terminals (46069). Both of these have 45° boots, but Taylor refers to them as 135°. I believe the LT1 optispark ends are straight, no angel. This may or may not suit your custom application.
Old Mar 9, 2020 | 10:38 PM
wannafbody's Avatar
Probably have to make custom length wires for a relocation kit.
Old Oct 4, 2020 | 11:51 PM
DoggyB22's Avatar
What you end up doing?
Old Oct 9, 2020 | 10:53 AM
17outs's Avatar
I bought mine from ICT Billet. And the crimper. Don't use that weakass dielectric grease though. Go buy permatex.
Old Nov 13, 2020 | 02:05 PM
DoggyB22's Avatar
Where did you put your relocation brackets at in your engine bay?
Old Nov 13, 2020 | 05:23 PM
Purple Poncho's Avatar
As an LT1 guy doing an LS coil conversion I can tell you the LS coil ends (D510C in my case) are 16mm wide and the LT1 optispark terminal/ends are 14mm. The LT1 opti ends of the wires fit on the LS coils but is pretty tight. I'm going with LS coil boots.
