5.3 harness vs 5.7 harness
Old Nov 28, 2020 | 07:20 PM
Matt.Pennington's Avatar
Default 5.3 harness vs 5.7 harness
can i use the 5.7 harness on a 5.3 application just plug in the 5.3 computer first timer here. any advice helps. or should i save the 5.3 harness
Old Nov 28, 2020 | 08:45 PM
What's the setup?
Old Nov 28, 2020 | 09:27 PM
B52bombardier1's Avatar
I'm thinking there will be connector differences, wire colors, wire count, etc. Use the 5.3 harness on the 5.3 engine.
Rick
Old Nov 28, 2020 | 09:33 PM
Originally Posted by G Atsma
What's the setup?
99 camaro z28 had 5.7 spun a bearing so got a 5.3 out of a suburban 02 was just gonna plug and play hopefully
Old Nov 28, 2020 | 10:42 PM
Use the 5.3 long block and all the 5.7 intake, ignition, accessories, etc.
You might need to tune it.
Old Dec 6, 2020 | 10:56 PM
Sacrilege's Avatar
Not gonna work the way you think. Not even remotely. What you’re gonna do is simply swap the long block and reuse every single part from the car. And I mean everything right down to the crank pulley. You will not be using anything from the truck, especially not the PCM (computer).
If you want to send out your camaro PCM to get reflashed with some better air/fuel/ignition tables that are more suited to the 5.3, you could do that, but if you plan on putting the 5.7 back in there, I wouldn’t waste the time or money.
Old Dec 7, 2020 | 09:44 AM
02Hawk1151's Avatar
I went through this same swap on a 2000 Z28. Yes you should use the stock 5.7 harness and the stock 5.7 computer (should change the tune to reflect 5.3L).
But as others have said, you will just be using the 5.3 long block. You will need to swap over the following from your 5.7:
Complete Intake
Coil packs (unless you want to make spacers to move the 5.3 driver side coil packs to clear the fuel line)
Front accessories including the water pump and crank pulley. To mount the alternator, you will need to drill and tap one boss on the block.
And don't forget the LS1 oil pan, windage tray, and oil pickup.
Think I had to change the Oil Pressure Sending Unit too, but the rest of the 5.3 sensors were fine iirc.
Old Dec 15, 2020 | 02:46 AM
Supramon808's Avatar
do u guys know if the color of the plastic connectors on the ecu matters? i know some of the truck are blue and red while some ls1 are green and blue. Would either one be able to be use as long as both are gen 3 engines?
Old Dec 15, 2020 | 07:00 AM
RB04Av's Avatar
AFAIK red & blue is drive by cable; green & blue is drive by wire.
Since you'll be using your LS1 intake and whatnot on the LM7, you'll need to stick with the red & blue.
Old Dec 15, 2020 | 04:55 PM
02Hawk1151's Avatar
Use your stock LS1 5.7 harness (blue and red) and the stock LS1 5.7 computer as previously stated.
Old Dec 15, 2020 | 10:03 PM
Sacrilege's Avatar
Both came both ways. The vast majority of red/blue were cable, and the vast majority of blue/green were wire, but you cannot generalize them like that.
And you cannot simply swap them, lots of things are different. lt1swap.com will tell you what needs to be changed.
Old Dec 16, 2020 | 12:12 AM
RevGTO's Avatar
Pontiacerator
Think of it this way. He is simply swapping one bare longblock for another. Everything else remains the same as it sits on his 99Z. All he has to do is drill and tap the hole for the alternator bolt and substitute the different displacement in the tune and he is good to go.
Of course there are things he can play with and modify if he wishes (PCV routing, etc.)
Old Feb 11, 2024 | 08:30 AM
marteezj4's Avatar
Default Will 2004 GTO 5.7 harness fit 5.3
Doing LS swap onnna 96 Camaro originally v6 will 5.7 harness buckle right up with my 5.3?
Old Feb 11, 2024 | 09:59 AM
Originally Posted by marteezj4
Doing an LS swap on a 96 Camaro that was originally v6.
Will 5.7 harness buckle right up with my 5.3?
If the connections are all the same, yes.
