Installing heads/cam with a torque converter
Old Jan 23, 2021 | 06:42 PM
KnoxCounty865's Avatar
Default Installing heads/cam with a torque converter
So I've ordered a Yank 3600 and some 243 Heads/a BTR3 cam to replace my 241s & stock cam. I was wondering could I install these at the same time ? After reading some threads some have mentioned how torque converters require a "break-in" period. And I also know I'd need a tune right after the H/C but I don't want to mess my new TC up getting a tune before breaking it in . What's the best route to go ? Should I install the TC first, drive around/break it in and then do the H/C later ? Also, could I get by without a tune running just the TC & 243 heads for a week or two ?
Thanks!
Old Jan 23, 2021 | 06:49 PM
ddnspider's Avatar
Do it all at once and get a tune. Your trans tables will need an adjustment when you do the converter and you'll definitely need a tune for the cam.
Old Jan 24, 2021 | 08:37 AM
SLP IROC-Z's Avatar
I dont recommend driving it with an aftermarket converter and no transmission tuning
Old Jan 24, 2021 | 08:55 AM
Bspeck82's Avatar
With that size cam I'd get it all done at once and tow it to the tuner. Try to avoid washing out the cylinders.
Old Jan 24, 2021 | 09:10 AM
98CayenneT/A's Avatar
Do everything at once, pull out PCM and have him load up a start up tune then drive it to him.
Old Jan 26, 2021 | 08:39 PM
Ok, sounds like getting it all done at once will be the best route. thanks for the input guys
Old Jan 27, 2021 | 07:26 AM
MonmouthCtyLS7's Avatar
I would definitely do it all at once w/ a tune.
Old Jan 27, 2021 | 05:01 PM
dannyz's Avatar
I second this
Old Jan 28, 2021 | 11:35 AM
LilJayV10's Avatar
convertor break in?
yeah it's called WOT.
