Exhaust Question(s)
What I want to accomplish:
Full-length exhaust.
I want a deep, throaty, rumbling, aggressive, little to no drone setup. When it is idling, I want to make its presence known. Revving, nice and deep growl. Flooring it from a standstill or moving and upshifting, I'd like to not hear ANY raspy or "tinny" sounds. Here's an example of a sound similar to what I am looking for, on a 5.7 newer HEMI Jeep Grand Cherokee:
No raspyness or tinny sound when he's winding it out in the video. Obviously, this is just a catback, and headers + high flow cats would make it louder.
Parts I've picked out:
- Kooks LT's 1 3/4ths
- Quad 4" tips out back
.....and that's as far as i've gotten. I would like to get opinions on which direction to go next:
- true duals?
- y-pipe to single intermediate pipe
- 2.5" or 3" diameter exhaust?
- high flow cats?
- brand of muffler(s) that meet the target goal?
I realize this is an offroad system, but for the little bit of sound you can hear in this video, it does seem appealing:
I also do not want or intend to go catless or have any cutout. This is a weekend cruiser/fun car, and I still want to be able to hear my radio at times above my exhaust.
I will also eventually get tuned.
It is just difficult to pick out the parts that meet my goal, since most videos and sound clips i've come across, people have had extensive work done (cam, heads, cutouts, O2 sims, no cats, 1/2 a cat, a real cat, a bunny, no muffler, etc.), and I only want to buy parts once to accomplish what I am trying to set out to do. Of course, all of this also with as much power gain as possible.
Any input would be appreciated. Thanks everyone.
I personally will never own a y pipe again because the duals sound so much better... and reading your post it appears that duals are probably what you need.
If I could recommend one thing it’s to step up the primary size to 1 7/8”... especially if you plan on adding more power. If not, they’re still fine.
Keep in mind if you cam it those cats need to go! I simply cut the cats off and welded 304 stainless (same grade of stainless as the rest of the system) in place of the cats.
For O2 simulators I would seriously consider not doing that and just getting it tuned and having the sensors cut off in the program. I still physically plugged in the sensors for my state inspection but in reality they were turned off.
This is exactly the information I am looking for, because until/if I do anything more crazy (heads/cam/etc), I only want to do this once.That said, it looks from what what you both are saying, true duals is the way to go for what I want, and either starting with Kooks headers and making my way back or Hooker Blackheart from the headers back, and since i'm no where near 600hp, and probably won't be, the 2.5" should work just fine, I gather. And of course, a proper tune will be in order after these upgrades.
I'll focus on these two for further research.
Thank you both for your input. Hopefully can make a decision in the coming weeks. Just will need to find more sound clips/videos.
I implemented the Bassani true duals, for my ride. It's a direct bolton, just lower to the ground. You should check the thread at the top of the forum, for extensive implementation of duals.
I have video, on my website, if you're interested in the sound of my implementation.
Since creating this thread, i'm pretty set on a true dual setup. When I had my C5, I had a catback Borla exhaust, with a Borla H-Pipe. Thinking of going that route via Kooks for the WS6, although I would most likely also do headers (required for their system).
Can you link your video? I'm interested in listening to how your setup sounds.
I think it sounds wonderful! It has a deep rumble, and clean. It's a true dual system, from Bassani. Although I messed around with adding ultraflows, it's basically a bolton system. There's nothing like true duals.
I have more video on my website, if you're interested.
https://youtu.be/pGqSpi7WduE
Any videos of the exhaust closer?
I've been through 6 or 7 systems. I know what to expect at this point.
Here's a couple of videos, showing the sound. It is badass, as it should be, with true duals!
This one is in my prior neighborhood, excuse the hauling ***, on the street.
This one is by a shop, that did the work, on my car. Little canny, but you can hear it!
Seems like its either impossible to get that sound on an Fbody, or it just needs true duals with the correct muffler. Kooks and Hooker so far seem to have mastered this for the Fbody. Still difficult, because nearly every video I come across with someone doing true duals, has other work done: cam, heads, etc. Which gives that lopey idle that I don't care for all that much. I don't have any engine work done, and for now, it will be headers with the exhaust if anything, and a tune.
