Ls1 Throttle body
https://www.ebay.com/itm/98-02-Camar...EAAOSwPkxfSegX
Here is the adapter plate if you want to use the 92mm
https://www.ebay.com/itm/Aluminum-92...oAAOSwWTRW16ei
Why do you sound like a lawyer, or is English your second language?
Any dyno test will prove my point about using a TB larger than the manifold inlet. It sounds like you are speaking from your imagination rather than actual proof.
So I don't SPEAK scientifically, but I thoroughly know the science behind everything about engines, and can explain it in everyday terms that anyone can understand
I've seen enough dyno tests to verify what I've said.
You are truly a legend in your own mind....
