85 mm MAF sensor
Old Jan 8, 2022 | 12:17 PM
2001ws6ft's Avatar
Default 85 mm MAF sensor
sorry, I know this question has been asked many times with differing answers. I would not even bother with a bigger maf except I'm getting to near 600rwhp soon. here's what I have:
92 fast intake and 92 mmm throttle body
ported heads
very mild cam (221/229, 116lsa, .6 lift)
1-7/8 headers
procharged
looking for 600rwhp depending on sc pulley
is an 85mm maf worth it? I will obviously be tuning my car in April.
Old Jan 8, 2022 | 12:22 PM
You might want to consider a speed density tune. Very common at that power level.
Old Jan 8, 2022 | 07:13 PM
02*C5's Avatar
ported heads
1-7/8 headers
procharged
Plenty of cars running an 85MM MAF and its more then enough at your power level. Once you start flowing enough air for 800+ rwhp is when I'd make the jump to 100 or do like stated above speed density tune.
Old Jan 8, 2022 | 07:52 PM
2001ws6ft's Avatar
I'll ask my tuner if he's going to do a speed density tune. At 600rwhp do you think it's worth going to the 85 vs the stock maf?
Old Jan 8, 2022 | 08:03 PM
02*C5's Avatar
In my experience the less restriction to air the better you're off. My last build I was pushing 540 rwhp and I had an 85 maf at the time with a ported LS2 intake/90mm throtle body. Now can you got too big of course. I wouldn't do a 100mm with 600 rwhp but you should be fine with an 85mm.
Old Jan 8, 2022 | 08:07 PM
pdxmotorhead's Avatar
A "stick" style MAF is might be an option, then it can just go in the intake tube somewhere in front of the throttle body. So there is no MAF restriction involved.
Not sure if the late style one is compatible with the early computers, but Porsche uses one as well Fomr the early 2000's.
Old Jan 8, 2022 | 09:02 PM
2001ws6ft's Avatar
thanks. I'll probably go 85mm maf if my tuner is ok with it. I believe the stock ls1 is 75mm. Just makes sense to go bigger since I have a 92mm throttle body. probably won't free too much flow,, but it's still a bottle neck in the intake system.
Old Jan 8, 2022 | 09:17 PM
02*C5's Avatar
I definitely think you'll be fine even with a 92MM tb and manifold. Let us know what he says and how it all turns out.
Old Jan 9, 2022 | 07:40 AM
2001ws6ft's Avatar
He said he would personally go with the 85mm maf because the stock ls1 maf is pretty small.
He didn't elaborate in his very brief email, but I'm guessing my suspicions are correct. It didn't sound like he thought it was a must.. It isn’t a massive restriction, but it still is a bottleneck.
I forgot to ask him if he's planning on doing a speed density tune. I've heard of some people doing a speed density tune and keeping the maf for data logging. Then again, tuning is like a foreign language to me.
Old Jan 9, 2022 | 07:59 PM
02*C5's Avatar
if you need one let me know I have one.
Old Jan 9, 2022 | 08:26 PM
2001ws6ft's Avatar
im interested. How much do you want for it with shipping? pm me
