Pacesetter Install Problem
Old Aug 2, 2004 | 12:25 AM
98Redta's Avatar
Default Pacesetter Install Problem
The install has been relatively easy just a little time consuming. We got the headers bolted on and the egr dont line up with the egr flange on the drivers side header. I have not checked the passenger side yet. We are planning on cutting the cars egr and rewelding it to line up with the egr header flange. Was this a factory screw up or something I just dont know. I have a 98 trans am. Please give me some input.
Old Aug 2, 2004 | 12:46 AM
Silver6sp's Avatar
i had the same problem, i just bent the egr tubes, they bend easy, for them to line up, pacesetter put the egr ports on the top for easy access, they didnt consider to check to see if they would line up
Old Aug 2, 2004 | 01:01 AM
2xLS1's Avatar
You have headers for a 00, 01 or 02. Those are your AIR tubes, not EGR. BTW the EGR flange on the passenger side header will be in a different location also.
Old Aug 2, 2004 | 07:20 AM
Mizfit MotorSports's Avatar
Plus if you are going to go to the trouble of cutting the factory egr and stuff you might as well just do block off plates.
Old Aug 2, 2004 | 11:00 AM
Bad Blu Formula's Avatar
Or order your headers without that stuff in the first place
Old Aug 2, 2004 | 04:42 PM
98Redta's Avatar
I didnt order them, I got the second hand and the guy told me they were 98-99. Any ways, guess I will try to make them line up. THanks.
Old Aug 2, 2004 | 06:44 PM
kenkaru's Avatar
A week after I installed my pacesetters, I ripped off all the AIR and EGR crap. I should have just ordered the no emissions headers but oh well. Just delete it. you'll be happy you did once you see how much crap comes out. There's a good how to if you search.
Old Aug 3, 2004 | 01:30 AM
kbronSS's Avatar
i did the same thing....only we heated them up a bit and then had bend them and they fit good enough, dont have any problems with them so far.
