To get rid of PCV do I just need some breathers?
Old 08-15-2004 | 08:23 PM
v8maro's Avatar
Default To get rid of PCV do I just need some breathers?
I want to delete my pcv, do I need a breather on each side or just one?
thanks
-Steve
Old 08-17-2004 | 05:12 PM
WILWAXU's Avatar
There's some info in this thread related to that:
https://ls1tech.com/forums/generation-iii-external-engine/197304-question-valve-cover-install.html
Also here:
https://ls1tech.com/forums/search.php?searchid=623709
Old 08-17-2004 | 06:06 PM
v8maro's Avatar
Welp, I am very confused now too.. Gunna have to read that a few times.
Old 08-17-2004 | 06:57 PM
AnthonyR's Avatar
one breather would work, or a catch can, or a catch can and a breather...
Old 08-17-2004 | 09:00 PM
Dustin Butts's Avatar
I plugged off my PCV. I run a big breather on the oil fill tube and a small one in the back of the DS valvecover. No problems. If your car is a daily driver a PCV system w/catch can would be better to suck out all those nasty vapors. I just change my oil frequently and do not daily drive the car.
Old 08-18-2004 | 01:02 AM
Phoenix 5.7's Avatar
there are bolt on breathers out there, but will it achieve anything to get rid of it?
Old 08-18-2004 | 01:06 AM
what is the point?
Old 08-18-2004 | 08:08 AM
My PCV was suckin quite a bit of oil that's why I d/c mine. I have the LS6 valley cover too.
Old 08-18-2004 | 09:43 AM
v8maro's Avatar
Well, I daily drive mine, and I have a catch can, how would I hook all this up? Maybe a little pic?
thanks
-Steve
Old 08-18-2004 | 11:01 PM
where did u get that paint done jancarich? I want a similar scheme
Old 08-19-2004 | 04:38 PM
thanks
-Steve
My PCV is completely plugged off even the LS6 valley cover. I just stuck two breather on there one on each side. If you already have a catch can just leave it and try plugging the fresh air intake off the TB. Then add a breather on the oil cap or a small breather on the drivers side valve cover.
Or better yet if you don't have the LS6 setup, run the pcv vacuum off the drivers side valve cover only(instead of the pass side) and put a breather on the oil cap(pass side). That way your pulling air across or "through" the engine and getting a good ventilation of your crankcase. If you drive your car daily or in traffic a lot I would recommend leaving the PCV system due to the build up of harmful vapors that can contaminate your oil and pit your bearings.
Old 08-19-2004 | 06:36 PM
JS's Avatar
JS
I've heard its not a good idea to run the engine with a close system and an open system together?Its better to run the car with either breathers or close pcv w/catch can?
Old 08-19-2004 | 07:50 PM
You could run it closed and then put a breather on at the track....
Old 08-20-2004 | 01:58 AM
JS's Avatar
JS
Yea I've heard thats okay too.
I think I;m gonna go breathers and see how she reacts...
Old 08-20-2004 | 10:47 AM
MyLS1Hauls's Avatar
I wouldnt get rid of the PCV on a daily driver. The PCV system helps keep the oil clean by getting rid of water vapor and pulling combustion by-products out. When you start up your car in cold weather, you'd be suprised how much water condenses in the oil. Water in the oil can form acidic compounds.
Old 08-20-2004 | 11:06 AM
JS's Avatar
JS
My car has 11K miles on it since 2000.
I dont drive it much,its a race car and I change the oil pretty regularly.
