runing straigh headers
Do it! Do it! Do it! Do it! Do it! Do it! Do it! Do it! Do it!
Just make sure you have O2 extensions so you can hook up the front O2's. There are frequently posts about running open header on the board, do a search on open header
It sounds SOOO badass and is CRAZY LOUD
FWIW: I ran open header for over a MONTH waiting for my duals apointment
You cab do it, but it's crazy loud. Especially with a cam! But the car runs like ***. It will draw vaccum when you let off the gas and suck fresh air up the headers a little way. Your 02's can read this causing a lean condition in the eyes of the computer. It will in turn add fuel and boom. Backfiring like a sumofabitch.
My car ran WAY faster and smoother once the exhaust was hooked up.
Yes, the fuel mileage is bad, no your eyes don't typically start burning, no typical stuttering.....I have read many threads about open header and never has anyone said anything like this
Yes, the fuel mileage is bad, no your eyes don't typically start burning, no typical stuttering.....I have read many threads about open header and never has anyone said anything like this The o2 sensors are too close to the edge of the collector. Air will contaminate the readings. Do you even know how the o2 sensor works and the effects it has on the car when they are contaminated with FRESH air. At idle your injector pulse widths will be 10 ms this is 40% dutycycle you do the math
This says the same thing it just doesnt go into too much detail
here is something to wet the whistle of you who tink open headers are cool
I said right off the bat that it would run pig rich. I still fail to see why it shouldn't be done. And I ABSOLUTEY DO NOT think that you should EVER run without the front 02's hooked up!!! Can a third (and possibly fourth, etc) party reading this post anything concrete on this please?
DO IT!!!
