Anyone extended their 02 sensor wires (homemade)
Old 09-01-2004, 12:32 PM
jason.sabovich's Avatar
Default Anyone extended their 02 sensor wires (homemade)
Has anyone just used the kit that comes with headers to extend their 02 sensor wires? It's an extra $50 you'd save by not buying extenders. It's just 8 wires to strip and attach new wires to. Everyone seems so against it, I don't see why, aside from it takes more work. As long as the connections are soldered I don't see a problem.
Old 09-01-2004, 03:41 PM
Hawkcmc's Avatar
I wouldnt see any issue with this, Just might not feel very professional to some. Maybe they are concerned with lack of a good connection leading to bad signals from the o2 sensors. Soldering should eliminate this though.
CMC
Old 09-01-2004, 03:42 PM
Jorday's Avatar
I did mine myself. It's worked without any trouble for over a year.
Old 09-02-2004, 12:53 AM
onyxxtreme's Avatar
everyones against extending the actual sensors' wires, not the wires that connect to the O2 sensor
the sensor wires are stainless or something, regular ol lead solder doesnt work with it
Old 09-02-2004, 06:11 AM
racrx's Avatar
I did it, no solder, worked fine for 2 years and counting!!!
Old 09-02-2004, 07:51 PM
mcflyz28's Avatar
I did it with butt connectors worked fine for a year, finally got extensions for 40 or so and it runs exactly the same.
Old 09-02-2004, 07:58 PM
10 Second Fun Car
jlrz28's Avatar
I did mine and had nothing but problems! Use your rear ones in the front if you need more length!
Old 09-03-2004, 01:26 AM
Cheatin' Chad's Avatar
I did.
crimp connector,Silver solder,heat shrink.
Works great and looks close to factory.
