Can this LS6 intake be fixed/saved?
It appears to them and me that the box was dropped on end and the intake fell inside the box on its back side, forcing the map sensor to push inward breaking the area where the MAP sensor mounts.
I was thinking of doing one of the following:
- JB welding the outside area that is missing and possibly fabricating something to keep the MAP sensor on it.
- Fabricating a piece of sheet metal (or machining some material) to make a new hole to mount the map sensor then bolting it on the rear of the intake maybe with some RTV in between the pieces.
- cutting a larger square shape piece from my LS1 intake and machining a taper or step then placing it into a hole cut out of the rear of the LS6 intake with the same taper or offset.
- gluing or JB welding the broken pieces to the inside of the rear side of the intake. This option scares me, because I would hate for a piece to break off and get sucked into the intake.
Here is a picture of the rear side of the intake:
Same picture, a little closer with better lighting:
here is the Map sensor mounting piece, which appears undamaged, and the pieces from inside the rear panel of the intake.
I think the only way to properly fix it it to use the same composite material (Nylon 66?) that the intake was originally made out of maybe?
I would at the very least have a plastics specialist handle it, if it can be fixed at all that is.
Just make sure that it's really clean, super clean!
http://www.circuitflex.com/LS6Fix.jpg
Dale
David
Ah, the downside to not purchasing from a sponsor
D
Dale
(as long as the pieces have been prepped clean).David
fabricators. I would for sure have them put a
smooth, proper diameter metal ring inside during
the process (maybe a deep socket will be a
fortunate fit) just to keep from warping the
seating cylinder.
JB is good too, just clean it three times as good
as you think it needs. Might scuff sand it too
where you can, that would give a better bite.
My chunk looked exactly like that except it was actually split into 2 chunks.
Dale
Dale
Have you ran your motor yet, or are you still in the build process? IF so, how many miles do you have on it?
Thanks,
David
The engine is waiting to be installed, but the bond from the JB is really strong. When I put the plastic adapter back in I ran some silicone around it and mounted it permanently. If it came loose I would be very suprised. But I am also considering a LS2 intake conversion. If parts for the conversion look economical I'll do that before it runs.
The only thing I'm really waiting on are my heads from Jay at Absolute and I expect them around the end of the month. Then it's showtime. 2,550 lbs of 280Z with a LS1/T56 crammed in it along with a 3.79 limited slip rearend.
I may be too scared to run it hard for a while so the vacuum should be high most of the time. I guess that's a good test for the intake.
I used JB weld and some wire to hold a column shifter together on an old Ford F150. When I sold the truck it had held up for 2 years and was still going strong. If it held up under that then I believe the intake will be fine as long as the area in question is super clean and roughed up a bit.
Dale
So what kind of detergent did you use? disgreaser of some type, laundry detergent or dishsoap?D
this may be a little off topic, but seeing this i have to get this off my chest.. stuff like this just chaps my azz..they will only insure packages to 100 dollars without purchasing additional insurance..maybee its just me but i dont think you should have to purchase additional insurance..i mean hell you do PAY for it to get there...i guess that doesnt specify if it will arrive in one piece..its like when they ask you "would you like additional insurance sir?" i just want to say, well hell are you telling me you might loose it or drop it? shouldnt you get it there without throwing it off a roof? just seems to me this is there way of being able to to loose,drop,damage people's stuff..in my opinion you should fill out a form stating the value of the package..then they can inspect it prior to shipping and note if any damage is done. next they should sign their name along with yours and let you read over what damage or conditions they see fit to note before you ship..if you agree and all is good..ship it, if its lost or damaged they should pay you for the declared value..no questions..you shouldnt have to "buy" insurance for a pacakge your paying them to ship..its there repsonsibility not yours.. ok im done..sorrymatt
). When I sell something on ebay or elsewhere, I do purchase additional insurance when the price is over $100 (though as you say, I shouldn't have to) just because I would hate for something to happen then I or the buyer lose out if the piece arrives broken or never arrives. THese are the first day, clamping the broken parts, one at a time and putting a little bit of JB weld to hold it in place. I would add more later.
I didnt want to build up on the inside as I was afraid the JB weld could break off and go in the heads. so I decided to reinforce the outside.
) I was told that it wasn't needed, and if I really wanted, I could use a wire tie to hold it on. The Fast 90mm Intake doesn't have a tab on it's piece.
I still chose to fix it (the stubborn guy that I am
