Swapped the ultra flo mufflers for super turbos in my duals
I cut the dynomax ultra flo mufflers out of my dumped true duals with x pipe and welded in a set of dynomax super turbos. I'm trying to quiet the car down some. It helped the noise some, but not as much as I had hoped. I originally had bullets in my true duals, which was insanely loud. Maybe I'll try and run the duals out the back one of these days. I think this would help the noise level in the car quite a bit. Anyone have any pics of 3 inch duals out the back?
1 Post
www.ls1sounds.com has a few pics..
Also do a search on here. I remember seeing one set that ran out the back.
check out http://www.sweet-thunder.com/ for a true dual out the back. There is a trans am on there some where with it. Looks like a true dual GMMG.
I have the turndowns turned out at about 45 degrees, but I'm starting to wonder if having them angled straight down is better for interior noise.
1 Post
I read that you should either turn them outwards or inward at an angle to sorta cancel each other out.
for a while I had no turndowns on the car when I used to have the ultra flo mufflers. I put the turndowns in and it made a huge difference in noise.
Originally Posted by dug
How does the turbo mufflers sound compared to the ultraflos? Deeper? Did you notice any difference in power?
The funny thing about comparing the noise level between the super turbos and the ultraflos is that the super turbos didn't seem to reduce the noise hardly at all below about 1300 rpm, but above that the car us much quieter than it was with the ultra flo.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
