looking to get headers
Old Sep 23, 2004 | 03:36 AM
TA_LS1's Avatar
Default looking to get headers
ok im looking to buy headers but i dont want to pay an outrageous price. so u guys know where i can get the best deal on headers? also how hard is installation having never done this before, or if i have a shop do it how much would it cost in general. lastly what do i need along with headers, such as a y-pipe, etc. thanks
Old Sep 23, 2004 | 03:43 AM
OnyxY2KSS's Avatar
pacesetters are just about the cheapest, and there are a lot of haters out there but im happy with mine also got pacesetter off road y pipe before the new design and have had no problems other than a little banging on the floorboard on a cold startup, did the installation with a friend, its pretty easy, knotched the k member a little and removed the steering knuckle, if you get no smog headers you will have to remove your EGR and AIR as i did and you will have to get 02 sims for the rear 02's and 02 extensions for the front 02's
Old Sep 23, 2004 | 03:01 PM
DustinWS6's Avatar
BlackY2KSS About summed it all up. I like my Pacesetters, but I have heard alot about them leaking around the header flange, but you can fix that by doubling up gaskets. I ordered mine from TSP
Old Sep 24, 2004 | 01:52 AM
Nocturnal SS's Avatar
Did you think about buying use ones?
Also i have a question about buying used headers? Would there be any problems with going in that direction?
Old Sep 24, 2004 | 01:29 PM
Matt D's Avatar
Retired Street Racer
if they are mildy used, go for it...saves you some money...i like the pacesetters, installed them on a friends car...pretty easy and straight forward install...i am not going with them on my car only because i am putting in a really big cam, and am going with the edlebrock victor series 1 3/4, stepped to 1 7/8in....the edlebrock's are reasonably priced at $495 for the headers, ory, and extensions.
Old Sep 24, 2004 | 03:09 PM
tomaSS's Avatar
Pacesetter's are cheap and fit great. If you live in a mild climate then the coating should last. The only thing I had to do was grind off the extra casting on the block. Very easy to do. The new design has a lot of clearance and didn't require notching of the K member. Got mine from speed-eng, they're a sponsor. But if you can pick up a set of high end headers for cheap, then I would go that route. But if you want new and don't wanna spend a lot of money, then Pacesetters work great. Also, do a search because there are tons of info on this site.
Old Sep 24, 2004 | 03:12 PM
EvilSVT's Avatar
Or you can go with a mac setup... just get a dremel a carbide bit ... port the primaries and your good to go .... make just as much power
Old Sep 24, 2004 | 05:58 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We have a new run of Pacesetter headers in stock & ready to go! We also stock one of our new TSP Y pipes available!!
Jason
Texas Speed
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
