QTP HVM LT's, QTP Dual Elect. Y-pipe, SLP 2OTL - First Driving Impressions
!LS1 11 Second Club
Let me start off by stating that I've had a few exhaust systems during the course of this car's lifespan.
Previous setups:
1st-SLP LT's and gutted cat SLP Y, Spintech catback with a cutout in the I (splitcase muffler didn't flow well).
2nd-SLP LT's, Custom 3" Mandrel Bent X-pipe dumped at the axle with Flowtech Afterburners (too loud).
3rd-Same SLP LT's, same X-pipe, but swapped in Magnaflow 4x9 Ovals instead of the Flowtech Afterburners (less loud).
New setup:
QTP HVM LT's, QTP Dual Cutout Y- with 4" Flowmaster Merge, SLP 2OTL catback.
Hands down, this is the best sounding setup I've had on my car yet. The X-pipe was sweet, the tone was high pitched at revs and deep at idle, very mechanical sounding- interesting in its own right.
But this Y pipe and SLP 2OTL sound in my mind, exactly what an F-bod exhaust should sound like- deep, mean and smooth. The sound pours on instead of shreeking like the X-pipe. The 2OTL is quiet at low revs, and intimdates at WOT.
With the cutouts open, all hell breaks loose, and you can make people in the lane next to you **** in fear (OK, I exaggerate, but it's much louder than I had imagined).
Torque down low has improved significantly- I don't know if it's due to the restriction of the catback, or if the QTP HVM LT's are doing their job- I'm hoping it's the High Velocity Merges working due to the $$$ I spent on them, hehe.
Next week, 90mm LSX and Dyno numbers.
Previous setups:
New setup:
how does the HVM compare to basic QTP LT's?...for 3-400 bucks (they had on that sale) is the extra power worth the money?...it seems like it might free up mayb 2-3 horses and mayb 2-3 ft-lbs if that...to the wheels...does that seem worth it?
!LS1 11 Second Club
The LT's on the HVM's are spliced together before reaching the collector (which also seems to be a bit smaller in diameter than the standard collector), instead of having 4 tubes dumping abrubtly into one collector.
02W6Bird, sound clips next week, I promise.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
!LS1 11 Second Club
dug,
The old X-pipe's empty cats would resonate a high pitched, metallic rasp when lifting off the throttle betweern shifts. This setup has a similar off throttle rasp, but is much more subtle, muffled and deeper. I can't say there are any on-throttle unwanted noises with the new setup. It is very smooth. I don't know why more F-bod people (Camaro owners especially due to no bumper cutouts) use the 2OTL.
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Supposedly one of the best flowing 'mufflered' cat backs as well.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Yeah, I dont know why more people dont run a 1otl catback. For around $200 you can have a very quiet highflowing catback. The 3" ipipe is only $100 from summit and then pick a 3" straight through muffler from magnaflow, ultraflo, or borla.
The best thing about them is that theyre quiet when driving around town and plenty loud at wot.
Kleeborp the Moderator™
Hmmmm...I'm starting to see a pattern here. People have a cat-back. People ditch cats, then hate rasp or performance. They get x-pipe, usually dumped. Switch mufflers around, get annoyed by the sound and interior resonance, go back to catback system (sometimes with or without cats). I'm hoping my over-the-axle duals takes care of this the first time to my satisfaction.
dug,
I just hate the look of single exit exhaust.
![Ripped](https://ls1tech.com/forums/images/smilies3/ripped.gif)
!LS1 11 Second Club
I had the car running on the setup for 1 day. The next day my clutch and rear end started acting up. It's been 2 months since I've had the car at a local shop. A new Moser 9" is being installed right now- a few misc. parts have held up the install. The Fast 90/90 setup is also installed. As soon as I get the car back, I'll record it.
I miss my car.
I miss my car.
