kooks stainless headers question
robby
They WILL retain heat better and improve performance if you do too
if you get stainless, just get stainless. I have ordered the Kooks stainless headers and y-pipe and they are awesome, i can post pictures if you want
is in keeping the O2s "lit" with enough exhaust heat.
I can't convince myself to buy mild steel headers, even
coated, seeing how some people are starting to pop
up with reports of their headers eroding through in
these forums and all so far are mild steel types. An
exterior-only coating won't help that and an interior
coating may not stay put either, given the huge
thermal cycling the near ends of the primaries see.
I think when I do get SS headers I will just wrap the
bits that can't be seen, with a few layers of aluminum
foil tape to cut the surface emissivity, and run the
higher wattage O2 sensors.
I'm just waiting for Edelbrock, or somebody, to come
out with the first mass-production, sub-$500 set of
stainless headers and a matching cheap stainless Y.
-Sean-
