MAC or KOOKS ground clearance?
Old 01-05-2005, 08:28 PM
OldeSkool's Avatar
Default MAC or KOOKS ground clearance?
ive decided to go with either stainless Kooks or locally coated MAC mid lengths, both will have off-road y's. I want to know which will have better ground clearance because I want to lower my SS
i've done a bunch of searching and I've heard good things about both as far as clearance but I want to know which is better.
Thanks!
Old 01-05-2005, 08:59 PM
AnthonyR's Avatar
Hands down the MAC's will give better clearance. I'm an inch lower all around and I never scrape.
Old 01-05-2005, 09:08 PM
destroyerSS's Avatar
I had mac's then switched to kook's and i would not switch back!! Hope this helps
Old 01-05-2005, 09:21 PM
98TAauto's Avatar
helped install a set of kooks on a car yesterday.. The definitly have better clearance then my SLP's! Probably a good inch or more.
Old 01-05-2005, 09:29 PM
LawmanSS's Avatar
I'll definitely second this statement!
Old 01-05-2005, 09:38 PM
Z28Venom's Avatar
Mid-lengths or Longtubes
Which would have better ground clearance?
COMMON FREAKIN SENSE!!
Old 01-05-2005, 09:55 PM
KrazyDan's Avatar
ive never seen macs but ive never had any problems with my kkoks
Old 01-05-2005, 10:40 PM
OldeSkool's Avatar
ok I know Kooks has a 3 inch collector and 3 inch y and the MACs use smaller diameter, but kooks is flattened on the drivers side so "common freaking sense" tells me it all depends on how flat the kooks drivers side pipe is and how close either the MAC or kooks y pipe is to the underside of the car... 2 things i can't tell from the pictures i've seen. But between the two, i've just about decided on kooks. But now i've read some more about stainless works and the delima continues
thanks guys
dave
