EGR Removal
Old Jan 6, 2005 | 08:07 PM
98 Camaro Z's Avatar
Default EGR Removal
What's the advantages and all in the removal of this? Is it really worth it. I don't think it will release any more hp will it? I've got it tuned out already. I just can't figure out what it will help out with. I've heard it hurts you gas mileage a little but what does that matter.
Old Jan 6, 2005 | 08:17 PM
5POINT7's Avatar
It doesn't add any power. It's for weight (very little at that) and it really just cleans up the engine bay.
Old Jan 6, 2005 | 08:28 PM
Cool! Not sure if I want to do that or not though.
Old Jan 6, 2005 | 09:07 PM
ddelallata's Avatar
I'm doing it as soon as I get my block off plates for the EGR and AIR that I ordered today. Now that I'll have some room on the front of the passenger side head I'm going to order an AMW catch can as well.
Old Jan 6, 2005 | 09:20 PM
LS1Maniac's Avatar
There's no reason to keep it that I can think of. It will help clean up your engine a lot since it's not dumping exhaust and sewt into your throttle body.
Old Jan 6, 2005 | 09:28 PM
TheBlurLS1's Avatar
That's what she said...
after removing my AIR/EGR, my engine compartment seemed to be alot smoother sounding, maby it just seemed that way, but i'm glad it's gone.
Old Jan 6, 2005 | 10:23 PM
2000Z28M6's Avatar
no codes from mine..........and its gone along with the AIR....Looks alot cleaner.
Old Jan 6, 2005 | 10:44 PM
LS1LT1's Avatar
Thumbs up
EGR and AIR are gone from my engine bay as well.
Old Jan 7, 2005 | 10:53 AM
I think I am going to do it now. Thanks Guys! I made my own plates for the air pump. So I'll just use that same stuff for the EGR too. What is an AMW catch can?
Old Jan 7, 2005 | 11:51 PM
I just pulled mine off. How is the best way to seal up the hole in the intake? Major vacuum leak there!
Old Jan 7, 2005 | 11:58 PM
blu98ta's Avatar
It is basically a filter for your pcv system, since our cars are notorious for sucking oil through it. The catch can just catches all the oil and prevents it from going into the engine. I've got one, and I am amazed at how much oil it has caught. It is worth buying!! Get a hold of Todd and get one!!
Old Jan 8, 2005 | 01:17 AM
Dustin 98TA's Avatar
Buy a LS6 intake.
Old Jan 9, 2005 | 02:36 AM
TheBlurLS1's Avatar
go to the autoparts store and buy a 1-3/8" (thats 1 and 3/8 of an inch) adjustable freeze plug. it looks like 2 washers with a piece of rubber between them and a nut on the top. turn the nut, it squeezes the washers together, expands the rubber, and seals the hole. i've got one on mine and it works great. Orileys had a 1-1/4" thru 1-3/8" one, as well as a 1-3/8" thru 1-1/2" inch. i got the first one and it worked great. only like 3 bux
Old Jan 9, 2005 | 02:55 AM
ss rally red's Avatar
Thats the ticket alright
Old Jan 9, 2005 | 03:23 AM
badjuju342's Avatar
Deranged Rat Fink
I'm going with the ' Vette LS6 intake and non A.I.R LTs . The SLP intake looks nice but incorporates the EGR still .
Old Jan 9, 2005 | 06:46 AM
xxboomer408xx's Avatar
so if i got race headders would i need block off plates if i took out my a.i.r. and egr?
Old Jan 9, 2005 | 02:31 PM
99Z28vert's Avatar
Race headers don't have egr or air provisions, so with those you'll only need a freeze plug to block off the egr hole on the intake.
Old Jan 9, 2005 | 02:52 PM
Yeah, one of the guys in the local f body club that I'm in had a 98. he told me about the freeze plug. Don't know why I didn't think of that. It worked perfect though. Thanks for the help!
Old Jan 11, 2005 | 06:50 PM
A-Bomb's Avatar
does anybody have any "Before and After" pics??? i'm interested in doing mine but, i wanted to see what it would look like.
Old Jan 11, 2005 | 09:43 PM
freakynipples69's Avatar
only reason I removed the EGR was because the LS6 intake I put it didn't have the provisions. I would do it if you ever plan on getting a LS6 intake or if you are just bored one day. Threw codes for me though.
