some help please!
Old Jan 9, 2005 | 08:51 PM
VaNDaL*SS*'s Avatar
Default some help please!
i installed a ported TB today that my friend had from his 01 SS that he is selling. he had a big cam in it TR236 i believe, he drilled the hole to be bigger for more air, so my problem is i put it on and it is idling weird. at first it is at about 8-900 but then i give it some gas and it will stay at where ever i revved to then drop back down to pretty much normal but a lil higher at about 1k. is the bigger hole in the plate the reason? cuz i still have my TB so i can put that one in the ported one
Old Jan 9, 2005 | 08:58 PM
VaNDaL*SS*'s Avatar
i know it is a dumb question but i want to make sure before i take it off again to swap plates, also to see if there is some alternate route of fixing it rather than swaping
thanks
Old Jan 9, 2005 | 10:14 PM
Dustin 98TA's Avatar
Go drive it for a while and see if it cures itself. I had a similar issue when I swapped my intake. The CPU needed to relearn.
Old Jan 10, 2005 | 12:04 AM
VaNDaL*SS*'s Avatar
how long did it take?
Old Jan 10, 2005 | 01:02 AM
VaNDaL*SS*'s Avatar
i also got an ASP UD pulley, i was curious if anyone had instructions as to how to put this on? also will i need new belts to do this?
Old Jan 10, 2005 | 01:45 AM
VaNDaL*SS*'s Avatar
k i found the instructions, where do i get new shorter belts?
Old Jan 10, 2005 | 02:01 AM
itchygomey98's Avatar
You could get the plate with the hole in it to work, but that seems like the long way around the race track to me. I would swap them out - that will make your life a lot easier IMHO.
Old Jan 10, 2005 | 02:28 AM
5-10 miles or so.
