how to remove washer fluid reservoir?
Old Feb 28, 2005 | 05:53 PM
00SSLS1's Avatar
Default how to remove washer fluid reservoir?
how do you guys remove it? I never drive it in the rain.
thanks
Old Feb 28, 2005 | 06:47 PM
Ron78Z&01SS's Avatar
It's your car and all but why bother? If it's for weight just leave the tank empty.
Old Feb 28, 2005 | 06:51 PM
00SSLS1's Avatar
well since its not my daily driver i was gonna remove it and put the fluid in my DD as it need some, so how would I do that?
Old Feb 28, 2005 | 08:56 PM
M6HuggerSS's Avatar
its not hard.... just pull off the upper radiator support, there are 4 clips, i think on the tank,... just pull them all of and slide it up between the radiator and crossmember.
it looks better, saves weight, and allows more air to hit the radiator.
Old Feb 28, 2005 | 09:01 PM
LS1Maniac's Avatar
I did it for the air purposes, not really for weight. I never used mine and it really cleans up the engine bay. It's pretty straight forward to remove, if you get under there with a flashlight you can see everything you need to remove.
Old Feb 28, 2005 | 09:46 PM
00SSLS1's Avatar
so i just need to remove those 4 clips on the reservior, nothing else? Does it then slide out from the bottom or from the top?
thanks guys
Old Feb 28, 2005 | 09:50 PM
Krab's Avatar
Slides out from the bottom. Be sure to disconnect the wire and line for the fluid before you go yanking down on it. You'll have to manuever it some to get it out.
Old Feb 28, 2005 | 11:00 PM
00SSLS1's Avatar
thanks
