Help with Engine Temperature Please
Old Apr 26, 2005 | 09:02 PM
JGA's Avatar
JGA
Default Help with Engine Temperature Please
Hi
As per my 1998 Z28 Camaro, A4, I have noticed it is running quite a bit hotter lately (as per factory gauge). It is getting from between 200 to 205 when ideling in traffic. Is this normal? It has the factory stat (195) and fan settings.
What temperature would be consdered as too high, 210, 220?
Thanks JA
Old Apr 26, 2005 | 09:08 PM
ddelallata's Avatar
That's normal. Don't worry about it.
Old Apr 26, 2005 | 09:09 PM
Griswold's Avatar
my car has always run just a hair under the 210 mark from the day I bought it four+ years ago. The factory gauge is pretty worthless though. It sounds like it is normal. If you are worried about it, you can always flush the coolant system and get a new thermostat and install a fan switch
Old Apr 26, 2005 | 09:36 PM
joshp14's Avatar
The factory gauge is a dummy gauge...it's pretty worthless...when compared to actual readings through a scantool, you would be surprised on the difference between the two.
Old Apr 26, 2005 | 09:47 PM
ddelallata's Avatar
he drives a 98, so his gauge is pretty accurate. It is still in within the normal range.
Old Apr 26, 2005 | 10:35 PM
JGA's Avatar
JGA
Hi
Thanks for the input. I have checked everything: drive belt, fan fuses, stat function, coolent level and all seems fine. The car just does not like to idle alot in hot weather. I think a low temp stat and Vinci hand held programmer are in order. They claim the programmer will be available anyday for the 98.
Thanks JA
Old Apr 26, 2005 | 11:17 PM
Diolar Magnum's Avatar
RIP April 14, 2008
From: the land where cars repeatedly hit my bumper when I'm in the store...
my 98 is the same way. its right where it should be. sitting in traffic for me I can get up to 210 or so. dont worry about it man.
Brad
Old Apr 27, 2005 | 10:48 AM
joshp14's Avatar
Ah yes, i remember now that 98 was the only year they actually made them somewhat accurate...
Old Apr 27, 2005 | 08:10 PM
JGA's Avatar
JGA
Hi
Thanks
JA
Old Apr 27, 2005 | 08:15 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Yep, sounds normal for a '98 gage in the warmer weather. They warm up quick when idling in warm weather, the stock fans don't cut on till 227 degrees.
