Is my stock y-pipe supposed to be this low?
Old Apr 27, 2005 | 08:29 PM
calys968's Avatar
Default Is my stock y-pipe supposed to be this low?
Is it normal for it to hang this low?
Old Apr 27, 2005 | 08:34 PM
2000NavyZ's Avatar
Looks about the same as mine:-/
Old Apr 27, 2005 | 08:35 PM
ulySSes's Avatar
No. What did you do?
Old Apr 27, 2005 | 08:40 PM
calys968's Avatar
I didn't do anything! That's the way I got the car
Old Apr 27, 2005 | 09:13 PM
Ferocity02's Avatar
Looks fine to me.
Old Apr 27, 2005 | 09:18 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Looks normal to me.
Old Apr 27, 2005 | 09:23 PM
777's Avatar
777
normal...
Old Apr 27, 2005 | 09:26 PM
Redneck Z's Avatar
Looks like my stock one did. I think I almost have more clearance now with my slp y-pipe than I did with my stocker.
Old Apr 27, 2005 | 10:35 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Looks pretty normal.
Here's a good test. Assuming you have stock ride height (stock springs/tire diameter/etc.), the driver's side of the Y-pipe should be about 4.5" from the ground......
Old Apr 27, 2005 | 10:50 PM
GT Griller's Avatar
Looks normal
Old Apr 28, 2005 | 07:44 AM
White.Lightning's Avatar
Mine needed to be adjusted slightly. If you have the car on a lift, check to see if one side of the pipe hangs lower than the other. For example, the passenger side pipe hung about a half inch lower than the driver side pipe. In this case, I loosened the clamps and turned the pipe so it was "level". Then just tighten the clamps. I was scraping the pipe on various "obstacles" when it was uneven. Hope this helps.
Andy
