Removed my AIR and have a question
diamond01SS - there is something else that needs to be plugged. There is a vacuum tube near the back of the passenger side head that will need to be plugged. I think this is on 01's and 02's only though.
There is a vacuum line hooked to that thing bolted on the back of the engine. It is on the the center, or top of it. We both have 01's, so I'm betting there is a vacuum line there. Sorry, I don't remember what size the bolt is, but it is a major PITA to get off. There are two bolts holding it on though.
If I remember correctly I just pulled the plastic part off and then took the bracket off. If you pull in the right direction, it will slide off the bracket with out breaking anything, then you can get at the bolts easier.
the black tree on the back of the motor for the 3 big lines can be pulled strait up and then there is a 10,13 or 15 mm bolt holding it on, i cant remember but i wanna say its a 13. once u break it loose the bolt will come out by hand, it was a major PITA for me though
