Please Help!!!
Old May 22, 2005 | 03:40 PM
RedWS601's Avatar
Default Please Help!!!
I was taking my stock manifold to install the FAST manifold and when i pulled it the stock one one of the fuel injector harness ripped. the wire I mean and also the burst panel wire ripped too. I'm going to put everything back and get it towed maybe. also there is a vacuum hole in the back of the manifold and I don't know how it goes, I need help
Old May 22, 2005 | 04:11 PM
SS1875's Avatar
What intake is on the car right now?? Stock or FAST.
Old May 22, 2005 | 06:07 PM
RedWS601's Avatar
I haven't finished it yet but I'm going to put on the FAST
Old May 22, 2005 | 06:42 PM
jimmyblue's Avatar
Moderator
What do you mean, ripped?
If you tore the insulation, electrical tape or heat shrink
tubing will cover it up. If you broke the conductor(s)
then solder in a little extra piece and then heat shrink.
"Burst panel wire", maybe is the MAP sensor? And the hole
is where it used to be?
Old May 22, 2005 | 06:50 PM
RedWS601's Avatar
Well the fuel injector clip, the one that you push up to take it off the injector, well that thing was ripped off the injector itslf. now on the manifold floor if you want to call it the block ceiling there are two hole and wires coming from both of them well the further back is ripped too
Old May 22, 2005 | 07:19 PM
SS1875's Avatar
Those sound like the knock sensor wires!! Are the connectors pulled off of the wires?? Do as JimmyBlue says above....if unable to fix then replace that part of the harness(last resort).
Old May 23, 2005 | 01:23 AM
RedWS601's Avatar
I'm just going to put back everything that I can and take it to the dealer. I am discouraged now, because I broke two things and I am clueless about what to do. I was going to do my headers next week but I'll let a pro do it now. Oh well. Like they say cheap things come out expensive in the end.
Old May 23, 2005 | 05:35 AM
USMARINE1108's Avatar
No, just fix it yourself! Wires are nothing to be afraid of, and a dealer is going to screw you over sooooooooooo bad. Fixing something is 70% confidence, 30% skill. That's what I always heard, and I think it's true. It dosen't sound like you realy messed anything up too bad anyway. Besides, the Titanic was built by professionals while the Ark was built by amateurs.
Old May 23, 2005 | 05:51 PM
SS1875's Avatar
I agree, dont give up yet!! Maybe take some pictures if you can of what is broken and we will try and help you out!!! We all have done something wrong the first time and had to fix it...you can to!!
Old May 23, 2005 | 06:53 PM
RedWS601's Avatar
wow that last sentence really made me want to get up take over the world now, you made me feel like I can't do anything now
RedWS601's Avatar
Ya I'll get pix and post them
