starting car without lid?
Old May 26, 2005 | 12:17 PM
bmfcamaro's Avatar
Default starting car without lid?
can i do this? will it hurt anything? i just got done with my heads install and want to fire it up but i sold my lid and am awaiting a tsp 85mm lid.
Old May 26, 2005 | 12:20 PM
conan's Avatar
As long as you have you MAF sensor on the TB you'll be fine.
Old May 26, 2005 | 12:42 PM
bmfcamaro's Avatar
im runnin in sd so i will place the maf there i guess and then just not plug it in.
Old May 26, 2005 | 12:48 PM
jimmyblue's Avatar
Moderator
I'd just be sure you're not in dirty conditions, including
the underhood grit, flying insects etc. Chunks not good.
Old May 26, 2005 | 12:49 PM
conan's Avatar
You should at least plug it in or it will run like **** because the engine wont know how much air it is getting.
Old May 26, 2005 | 12:53 PM
bmfcamaro's Avatar
i wont be driving it just letting it idle in garage. as for air calculations that is why we tune the ve table. so you can eliminate the maf.
Old May 26, 2005 | 12:56 PM
8-Pack's Avatar
If your running speed density then you dont need a MAF. And I would try to buy a filter and attach that to your bellows with a hose clamp if you are going to fire it up.
Old May 26, 2005 | 12:59 PM
777's Avatar
777
you don't want crap getting in there, or you might be having to buy a new engine
Old May 26, 2005 | 01:51 PM
conan's Avatar
Sorry I didn't understand the "sd" part.
Old May 26, 2005 | 01:54 PM
Griswold's Avatar
I don't know if SD uses the sensor that is on the lid, but you should plug that in if it does.
Old May 26, 2005 | 01:59 PM
Steve Burger's Avatar
LS1TECH Sponsor
I don't think SD (Speed Density) uses the IAT.
