harmonic balancer bolt.
Old Jun 5, 2005 | 10:06 AM
nvrstsfd23's Avatar
Default harmonic balancer bolt.
I replaced the bolt after the cam swap but now we have to take it out. will I need to buy a new one or is the one I have ok since it was only used for a day.
Old Jun 5, 2005 | 10:37 AM
SideStep's Avatar
You will have to replace it if it is a factory GM crank bolt, it has stretched... Don't risk it.... Heck they are only $7-10....
Old Jun 5, 2005 | 05:45 PM
lsx24's Avatar
Hmm don't make a mistake, the required bolt is relatively low cost and can be replaced when removing the pulley.
Old Jun 5, 2005 | 06:46 PM
Red99TA's Avatar
The bolt is designed to stretch when you put that final 120 degree turn on it when tightening down. As a result once it's removed you need a new one. They're called torque to yield bolts b/c you're taking the bolt to it's yield point and it has permanent plastic deformation after that (it's stretched).
Old Jun 5, 2005 | 06:55 PM
redbandit98's Avatar
while on the subject whos got the best deal on an arp? hell this buying a new bolt (for the 4th time i think) is getting expensive....i always say ok this is the last time its coming apart then..6 months later its down again.hahahh
Old Jun 5, 2005 | 07:30 PM
ss rally red's Avatar
I dont know how much the ARP bolt is but make sure you have a 12 point socket when you install it........
by the way my cost on the GM bolt is 2.76.
Old Jun 5, 2005 | 07:44 PM
conan's Avatar
I got my arp bolt from thunder about 25$$ .
Old Jun 5, 2005 | 09:50 PM
ChucksZ06's Avatar
I personally believe replacing the bolt is a load of crap. The bolt may not be as elastic as it was but who cares...it sure isn't going to break. Put a dap of silicone on the treads and under the washer and it will never come off until you want it to. It is not like it is a head bolt that has really been stretched.
Old Jun 5, 2005 | 09:58 PM
rush7's Avatar
my opinion: replace the bolt with an ARP and be done with it. it is a quality piece of metal.
Old Jun 5, 2005 | 10:40 PM
technical's Avatar
Torque to yield is just that...yield(point of failure/stretch)
It doesn't matter what type or size of bolt it is...TTY fasteners are only "good" for one use.(torque-ing) Even non TTY fasteners are only good for a limited number of torque-ings.
Just the facts ma'am.
Old Jun 6, 2005 | 01:40 AM
digitalsolo's Avatar
I'm just curious of anyone who has installed a used bolt properly and had a failure? I've reused TTY bolts on rockers, and crank several times (pulling rockers on and off on my L67 car, probably 5 installs on the bolts, 45K miles, no failures). Just relube them, and you're good to go, if you install them right.
...that or spend 3 bucks. That's what I did for my new balancer bolt.
Old Jun 6, 2005 | 01:56 AM
DONAIMIAN's Avatar
ive heard of people not buying a new one without having any failures, would I do it, if I was in a bind yea, but if I was in no hurry id just get a new one.
Old Jun 6, 2005 | 02:32 AM
chpmnsws6's Avatar
my buddy re-used his factory bolt and had the pulley fly off while the car was at 6800rpm
Old Jun 6, 2005 | 03:11 PM
Red99TA's Avatar
Was there any evidence of the bolt breaking or was it completely gone (like it just backed out)?
Old Jun 6, 2005 | 03:20 PM
chpmnsws6's Avatar
it had backed out.
he put that bolt on TIGHT to... 200+ pound man lifting himself up by the breaker bar
Old Jun 6, 2005 | 03:32 PM
2xLS1's Avatar
200+ pound man lifting himself up by the breaker bar doesn't mean it was tq'd to 37 ft lbs then turned another 140* though.
Old Jun 6, 2005 | 03:33 PM
technical's Avatar
Originally Posted by digitalsolo
... Just relube them, and you're good to go, if you install them right.
The correct install is to replace the bolt. If they're going to break they typically they will break during torque-ing. Otherwise you just don't get the correct tension and they either back out like the above post stated or they don't provide the correct seal... e.g. a head gasket.
Old Jun 6, 2005 | 11:45 PM
chpmnsws6's Avatar
can't really do much more then that
Old Jun 7, 2005 | 12:29 AM
2xLS1's Avatar
Then be prepared to keep losing bolts. With a long enough cheater bar, the bolt can be turned 140* easily. I use a 3/4" drive breaker bar with a 3' piece of pipe. I actually have to be careful not to go past 140*. I use the Kent Moore F/W locking tool also. On over 25 cam installs, I've never had a crank bolt come loose.
Old Jun 7, 2005 | 07:13 AM
Tally TransAm's Avatar
agreed
i weigh 125#'s and even i can get it to 140
