Specs for Sweet Thunder
Old Jun 7, 2005 | 07:20 PM
AbsolutHank's Avatar
Question Specs for Sweet Thunder
I have a LM on my 98 TA....what exactly are the specs for a weld in Sweet Thunder Muffler to go in place of the resonator? I am assuming 18" long, 3" in and out...just a little guidance please
Old Jun 7, 2005 | 07:39 PM
Z28Venom's Avatar
Actually,
The 18" muffler is 24" total. The 3" has a 3" inlet/outlet, but it has a 2.5" core.
In all honesty, the Sweet Thunder isn't the best option for replacing the resonator. I would look into a Borla XR-1 ( 40085 ).
Old Jun 8, 2005 | 05:52 AM
With the location of the resonator, and my car being lowered, I read that the Borla has even worse ground clearance issues...is that true??
Old Jun 8, 2005 | 07:47 AM
1CAMWNDR's Avatar
The Borla has a larger body so yes, ground clearance will be an issue. The Sweet Thunder mufflers have a 3" body. They will not be any larger than your IM pipe.
Old Jun 8, 2005 | 04:47 PM
Alright, back to the original question....why isnt the Sweet Thunder a good replacement for the resonator?
Old Jun 8, 2005 | 05:01 PM
Uno99's Avatar
The resonator is 3" all the way through. Sweet thunder Narrow down to 2.5" inside. They sound great.
Old Jun 8, 2005 | 06:38 PM
Well, other than a few bolt on's, the car is stock and will stay that way....what I care most about is the sound, not the 3 hp going back down to 2.5" might give up. I bought the car with the LM already installed, and its just obnoxious as hell...not to mention it sounds like a giant fart cannon borrowed from a Honda....i want something with a mean sound, not necessarily loud with alot of rasp and popping back like the LM...thanks again
Old Jun 8, 2005 | 07:16 PM
Flaminchiten67's Avatar
What I was going to look into for my LM was a 1 chamber 3.5 inch in/out flowmaster. The pipe on the LM is 3 inch but the resonator goes to 3.5 inch I believe. I have never heard this setup but think it would refine the sound just enough without making it too quiet.
Here are the muffler specs:
Part #: 389-9435109
In/Out: 3-1/2''
Body: 6-1/4''
Chambers: 1
Old Jun 8, 2005 | 08:51 PM
kpowr82's Avatar
Part #: 389-9435109
In/Out: 3-1/2''
Body: 6-1/4''
Chambers: 1
Did you see the width on that bad boy? 10.25" not gonna fit my friend. Not without some modifications anyhow.
FWIW, the LM resonator swells to a 4" diameter I think. I'll have to measure it. I've toyed with the idea of adding a sweet thunder I've got laying around into my current setup, but don't want to lose the horsies up top. Planning on a cam soon too, so I don't want to choke it up.
Old Jun 9, 2005 | 07:23 AM
LS1 Hawkeye's Avatar
I put a 3" sweet thunder in the I-pipe of my Z and the sound is great, over the stock muffler that is. I wasn't really all that worried about any loss in power either. It was pretty much to wake to exhaust up for now. When I get my headers next year I'll be going to true duel over the axle anyhow.
Old Jun 9, 2005 | 08:30 AM
Uno99's Avatar
I say do it My buddy has done it on his Ws6 and it sound great. Just throw a cut-out on front of the Sweet thunder. Best of both worlds. Great sound and good flow.
Old Jun 9, 2005 | 10:03 AM
silver02Z's Avatar
http://www.sweet-thunder.com/chamber....html#aluminum
If you don't find the info you need then you can e-mail them and they are quick to respond..
Kevin
Old Jun 9, 2005 | 12:53 PM
I think it will fit. I have seen some pics of it and it doesnt look too bad.
https://ls1tech.com/forums/showthrea...ed+before+axle
Old Jun 9, 2005 | 07:54 PM
kpowr82's Avatar
That link doesn't work. I wanna check those pics out though. I'd like to refine the sound of my Hooker and ORY a little bit. Think you could check out that link and fix it real quick?
Old Jun 10, 2005 | 10:21 AM
O.K. try this one.
https://ls1tech.com/forums/generation-iii-external-engine/274298-ypipe-single-muffler-dumped-before-axle.html
It's a custom setup but I think it could still be doable on a LM by an exhaust shop. I think the one used here is a 2 chamber.
Old Jun 10, 2005 | 11:38 PM
prince xizor's Avatar
what would happen if you would cover the gap in the I pipe and put the resonators out the back before the tips? Just use 2 mufflers instead of one?
Old Jun 12, 2005 | 02:16 PM
There is a thread that I remember where the guy put 2 one chambers in his tail pipes of his LM. I am too lazy to search for it right now, but he said it sounded really good.
