Intalling the LS6 Intake
Old Jun 12, 2005 | 09:07 PM
RrCoX22's Avatar
Default Intalling the LS6 Intake
I heard that I should probably install the LS6 intake manifold myself. have a '99 z-28 and kinda new to all of the mods. curious on on long it would take for installation.
Old Jun 12, 2005 | 09:27 PM
2000 LS1 Z's Avatar
It's not that bad. Took me and a buddy about 2 hrs are 1st time..
Crazy Man's Avatar
Since you havent ever delt with a ls1 before probly 4hrs not to hard of a swap. just take your time dont pinch the injector orings and have patience when removing the gas line lol
Old Jun 12, 2005 | 09:46 PM
Lithium's Avatar
SSU's Drunk Typing Whore
it took me about 6 hours to do by myself. It was my first time as well, its not at all hard, its just some damn time consuming is all.
Old Jun 12, 2005 | 09:58 PM
Stark's Avatar
It's not that hard, like others have stated, just take your time. A small, thin drop light will help you see under the cowl for where the rear plugs need to go. I think i spent 4 hours on mine as well. Good luck!
Old Jun 13, 2005 | 10:59 AM
01 Red WS6's Avatar
Don't forget to remove the stuff on the back of the intake. I can't tell you how many I've seen break something off back there
Old Jun 13, 2005 | 10:30 PM
Gregg 00SS's Avatar
Be ready to join the "I broke my oil pressure sensor" club, hahaha.
Old Jun 14, 2005 | 01:19 AM
Y2K SS's Avatar
Dude go to LS1Howto.com there is a serious write up there tells you step by step.
Old Jun 14, 2005 | 09:46 AM
VTC_WS6's Avatar
Good info, I'll be installing an LS6 intake this weekend too!
Old Jun 14, 2005 | 09:52 AM
Bryan @ Speed Inc.'s Avatar
yup.... first time i had the intake off i snapped it... but i just installed the fast ls-x intake over the weekend... took me a while by myself, but it's very straightforward and pretty easy... just time consuming if you don't have a helping hand. go to auto zone or something and get the fuel rail disconnect tool (absolutely neccessary)... cheap, easy, just be patient while removing it. yea ls1howto.com has a great write up on it, AND fast comes w/ instructions... use some 1/4" hose and cut it in 1" lengths and slit it down the middle of the hose. cut 5 of those and when you get the 5 most rear ward bolts ran out, lift them up and put the hose around the bolts so you can lift the intake out. (they wont come all of the way out becuase of the cowl). that worked BEAUTIFULLY for me. good luck man.
Old Jun 15, 2005 | 04:49 AM
Gregg 00SS's Avatar
Excellent idea, I used tape, but that was a PITA. I'm gonna try your idea when I remove my intake to lay down a little more silicone for a good seal.
Old Jun 15, 2005 | 10:27 AM
yea i wish i thought of it... those engineers at f.a.s.t. have EVERYTHING covered. lol. you're putting silicon on yoru intake?
Old Jun 15, 2005 | 12:42 PM
JustAnIlluzion's Avatar
what are people doing with the knock sensors? replacing them just incase? anyone putting a wall of rtv around them so they wont corrode?
