GM Perf. vs. SLP LS6 Intake?
Old Aug 3, 2005 | 05:50 PM
RrCoX22's Avatar
Default GM Perf. vs. SLP LS6 Intake?
Is there any difference between the two manufactures for the LS6 Intake. Wondering if there is any cons from either one even though I wouldn't think there would be much of a difference from the two. I'm gonna have to get one with the EGR provision to stay smog legal here in CA. Just curious on your guy's input.
Old Aug 3, 2005 | 05:56 PM
Redneck Z's Avatar
If you want to use the egr get the SLP. This is the only one that allows you to use your egr. I think SDPC might sell a kit to convert the LS6 intake to be used with your egr.
Old Aug 3, 2005 | 05:58 PM
Camaro99SS's Avatar
The GM intake doesn't have EGR. The SLP intake does. Otherwise both the same thing.
Jason
Old Aug 4, 2005 | 01:54 AM
RrCoX22's Avatar
GM Performance make the LS6 Intake w/EGR.....Speed Inc. has it.....so far from what I've seen.
Old Aug 4, 2005 | 02:06 AM
Redneck Z's Avatar
If speed inc. uses something other than the SLP way of hooking up the egr I would go that route. Quite a few people have had problems the their SLP intake leaking at the egr connection. Mine hasn't yet(knock on wood), but when I disconnected it I could see that the threads in the brass nut were already starting to wear. This is after only a thousand or so miles. I don't know how long it will last before I have a leak, and I think it might be difficult to find a replacement. I would try something else if I had to do it over again.
Old Aug 4, 2005 | 02:10 AM
Lithium's Avatar
SSU's Drunk Typing Whore
The only reason why I went with the SLP was because of the EGR. Other wise they are the same thing.
Old Aug 4, 2005 | 04:38 PM
RrCoX22's Avatar
.....ok yall..........GM Perf. has a LS6 Intake w/ EGR too, wondering if anyone prefered one over the other.
Old Aug 4, 2005 | 06:02 PM
M6HuggerSS's Avatar
find a better place to mount the turbo
i believe you are WRONG!
show me the link to the GM site that shows it!
Old Aug 5, 2005 | 12:33 AM
felton316's Avatar
I think you got the wrong thread......
Old Aug 5, 2005 | 06:47 AM
M6HuggerSS's Avatar
hahaha.... ya forget about the turbo part.... hahahahaha
Old Aug 5, 2005 | 05:35 PM
RrCoX22's Avatar
read above son.....Speed Inc. - if your lazy to scroll, also believe there's a few other sponsors
Old Aug 6, 2005 | 08:10 AM
M6HuggerSS's Avatar
i saw the one on LS1 speed and it is a modified GM intake. like the SLP.
