Gettin ready for my Pacesetter's... Whats needed?
There was a good post about !AIR on here...AIR removal You're looking for the #20 post in the thread. There's also a link to another write up he read before taking it off.
The headers come with them? Then how come Texas Speed doesnt say that on their website... those punks
Basically I need:
Headers
extensions (Included)
spark plugs and wires (while im there)
and then get the exhaust built...
and maybe a tune for a little more power
Also if you're planning to remove the AIR do it when you're installing the headers, in fact don't even worry about block off plates just buy the race style headers.
The time you'll spend removing the AIR system would be wasted screwing around with aligning the air tubes with the fittings on the headers.
I just removed my AIR and I wish I would have done it that way from the get go.
Have the AIR codes programmed out along with the rear 02's
! 2. Y-pipe
3. 3 GOOD clamps. The band style that Napa sells. About 10 bucks each.
4. GM Metal gaskets (buy them, don't reuse factory)
5. NGK's left at gap them come in or regap if you want
6. MSD or equivalent or stock wires
7. Remove Air System https://ls1tech.com/forums/generation-iii-external-engine/328977-exhaust-backfires-running-rich-poor-mileage-come-air-removal.html
That link tells you EVERYTHING you need to know about removing the AIR system.
8. Factory, Pacesetter, or Locking stage 8 header bolts.
Get the car up as high as you can. Having the oil filter off made it easier for me to get mine in there. Nothing else has to be moved or removed to get them in. Just patience and some careful small movements.
i paid $525. Thats 400 for the race ceramic coated headers and 125 for the piece of **** ory. free shipping too.
