how much to install???
Old Aug 31, 2005 | 12:53 PM
Z28LS1camaroguy's Avatar
Default how much to install???
i have my exhaust cutout finally and am gonna get it welded at the I-pipe where the knotch is under the passenger side, and i am wondering how much do u think it would cost to have an exhaust shop do this?? i dont want it to be over 200 i was thinking more along the lines of 50-100 dollar range.
Old Aug 31, 2005 | 12:56 PM
Redneck Z's Avatar
A muffler shop made me a cutout and installed it for $60. It should be less just to weld yours on. They probably charge close to $100 an hour, and it should take them 10 or 15 minutes.
Old Aug 31, 2005 | 01:08 PM
SSBRONCS's Avatar
i paid about $30
Old Aug 31, 2005 | 01:27 PM
ok thats a relief, but where did u have yours installed at, by the muffler or up under the passenger side thing.
Old Aug 31, 2005 | 03:43 PM
777's Avatar
777
At the I pipe. After the merge but before the muffer.
Old Aug 31, 2005 | 04:35 PM
Redneck Z's Avatar
I have had mine at both locations and prefer it just before the muffler. There won't be a difference in power between the two locations, and the zed style has less drone and is easier to get to.
Old Aug 31, 2005 | 10:59 PM
are they the same in loudness or does it make it less rumbly the furture back you go??
Old Sep 1, 2005 | 12:18 PM
99redlightning's Avatar
I just got mine in the middle of the I pipe at Midas for 30$. If they charge over that, go somewhere else. Only took about 30 mins with all the welding. It sounds kickass.
Old Sep 1, 2005 | 12:24 PM
01formula6's Avatar
It cost me $40 out the door at Merlins.
Old Sep 1, 2005 | 01:54 PM
01 Red WS6's Avatar
I paid $20 to get it done
Old Sep 1, 2005 | 08:10 PM
still didnt answer my question of does it sound the same if you weld it under the passenger seat or by the muffler??
Old Sep 1, 2005 | 09:03 PM
2_wacko's Avatar
I paid $60 buck for mine installed, the shop made it.
Old Sep 1, 2005 | 09:19 PM
ok but does it affect the sound where you place the cutout on the exhaust pipes???
Old Sep 1, 2005 | 10:01 PM
Redneck Z's Avatar
Yeah, it does. If you put in in the I-pipe it will sound deeper because the sound will bounce back off the pavement more. The downfall is that you will get a lot more interior drone and heat under your floor board. My latest and favorite setup by far, has the cutout just before the muffler and a plate over the cutout with a 1 1/4" hole. I had a muffler shop make a plate to bolt to my cutout with 1 1/4" hole in it. It makes my magnaflow exhaust sound much more throaty/aggressive, but isn't obnoxiously loud and doesn't have the drone of an open 3" cutout.
Old Sep 1, 2005 | 10:39 PM
it wont hurt anything if i have it put under the floorboard right, my car wont catch on fire right lol.
Old Sep 1, 2005 | 10:49 PM
Redneck Z's Avatar
Probably not. If you want to put it under the car, use the space that looks like it was made for a cutout. It's just before the I-pipe goes up over the axle. Angle the cutout at about a 45 degree angle between the side of the car and the ground.
Old Sep 1, 2005 | 10:59 PM
yeah thats the spot that i was talking about, i heard about it and was like yeah definatly want it there and expect it to be loud. especially after i get pacesetter long tube headers lol
Old Sep 1, 2005 | 11:28 PM
also did u have to grind some of the welds down on the inside of the cutout, bc it has a lip on the inside all around where they welded.
Old Sep 1, 2005 | 11:41 PM
Redneck Z's Avatar
You could, but it probably isn't worth it.
Old Sep 2, 2005 | 08:40 AM
ok well i just wanted to know if it is normal.
