after a run, coolant pours out from reservoir
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
please enlighten me on this issue,
I have been driving the car some and after a good drive (say 50 miles) after I get to park it, the coolant starts to pour from the overfill reservoir.
I went ahead and took it out to check if it was leaking and cleaned it good, I have been having to top the coolant with water because it pours about 1 gallon every time, there are no holes and the car does not overheat. but I do get the low coolant light, and when I go top it off, sure enough there is low fluid there.
why is it building pressure....I just drained the old fluid when I took the engine out, the engine was drained as well.
-is there a possibility that there is air in the system causing the pressure buildup?
I put some rtv on the tube that comes from the radiator to the reservoir, on the point where the aluminum tube goes into the reservoir because it was pouring from there and now it comes from the top if the neck.
I cannot think through this one, it seems odd to me.
let me know what might couse coolant to build up and overflow in the reservoir. (even when I emptied it out to make sure there was not a lot of fluid in the system.
thanks in advance
David
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
thanks in advance
David
Originally Posted by 98hc4mula
I dont know for sure, the coolant line to the block near the radiator cap is the one on the top right?
I put the one on the lower part to the overflow...is this wrong?
ohh man I hope this is it.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
The same thing happened to me. I car was puking up coolant out of the overflow after a dyno run. Turns out the filler neck and cap were cracked. You may look into that if in fact you do have the hoses in the right spots
I did check them and had to change them, they were wrong, no more pucking fluid,thanks a lot to sux2bu for helping me figure it out, I would have never guess that.
now All i have to fix its the damn oil leak from the rear of the engine, RPM is going to look at it tomorrow and fix it, I have been in contact with the engine builder and told him about my problem......see what happens
thanks again
David
thanks again
David
