What can i do when i get LTs?
Old Nov 26, 2005 | 12:03 PM
Superman09's Avatar
LS1Tech Sponsor
Default What can i do when i get LTs?
Hello guys, im oging to be ordering my LTs here soon and i need to know what to do with my exhaust. I have borla catback now, but i hear it will sound horrible with LTs and ORY. I need to know if i can change the muffler in my borla or what to get abetter sound. I was thinking of selling the borla and getting the LTs with TSP X pipe sweet thunder set up, but i am lowered 2" so how bad would clearance really be? Also i am a TA and hate the look with no exhaust tips........ Should i try and modify my borla, i dont want to restrict flow by using all block off plates, i jsut want a free flowing exhaust that sounds mean as hell. Suggestions? Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Nov 26, 2005 | 12:09 PM
blue01ta's Avatar
If money is not an issue get true duals out the back. To me that is what sounds the best but it is not cheap.
Superman09's Avatar
LS1Tech Sponsor
Yea, but than will i still suffer clearance issues?
__________________
Old Nov 26, 2005 | 12:27 PM
joblo1978's Avatar
Why not get a catted y?
Old Nov 26, 2005 | 12:30 PM
Superman09's Avatar
LS1Tech Sponsor
So will LTs, borla and catted y still flow enough to make it worth the cash? And how will it change the sound. I want a deep rumble and insane loud at WOT
__________________
Old Nov 26, 2005 | 01:39 PM
parbreak's Avatar
Deep rumble and insane loud at wide open throttle= LTs + Loudmouth
Old Nov 26, 2005 | 02:10 PM
Superman09's Avatar
LS1Tech Sponsor
yea but that has insanely nasty rasp...... Guy i know has LTs, ory and Loudmouthand its too loud, gross IMO, i jsut want a nice rumble like my borla has now but louder, i jsut want a nice rumble and louder without gross trucker rasp. Any ideas?
__________________
Old Nov 26, 2005 | 02:11 PM
GTObsessor's Avatar
^^^^^^^^^^ Cats = MABY a 5 HP loss at the wheels... maby... get some good high-flow cats on there.
Old Nov 26, 2005 | 02:22 PM
Superman09's Avatar
LS1Tech Sponsor
So you suggest i keep my borla, get the pacesetters, and an ORY and buy some hi flow cats for it? What is a good y-pipe and good cats to get? Dont want to get too pricey here. thanks
__________________
Old Nov 26, 2005 | 02:43 PM
Superman09's Avatar
LS1Tech Sponsor
I think i might want to stay away from the cats and jsut run an ORY, i dont want to be losing power even though its not much. Any suggestions?
__________________
Old Nov 26, 2005 | 04:36 PM
CarnivorWS.6-01's Avatar
Look into TSP catted Y. You can get Pacesetter coateds and Catted Y for $700 plus shipping. Having them installed on mine Friday. I have Hooker catback and love the sound. Sounds beastly at WOT but nice and quiet at cruise.
Old Nov 26, 2005 | 04:49 PM
Superman09's Avatar
LS1Tech Sponsor
Yea. not sure if i really want to go with a catted y. I might jsut get LTs and ORY and play around with my plates and if it all sounds horrible, might look into a new exhaust.
__________________
Old Nov 26, 2005 | 08:07 PM
skewba98z28's Avatar
You can always weld the XR1 muffler in the I-pipe. That's what I will have in less than a month. Flowtech Coated LT's, ORY, and Borlamouth. The XR1 in the LM should have the same affect as a XR1 in a Borla Cat-back.
Old Nov 27, 2005 | 12:38 AM
Superman09's Avatar
LS1Tech Sponsor
Can i weld the XR1 muffler into my catback?
__________________
Old Nov 27, 2005 | 12:39 AM
Superman09's Avatar
LS1Tech Sponsor
Maybe ill like the sound of the LTs/ory/borla, I really want a loud idle/rumble and deadly at WOT so i may like it, but if the rasp is too much or tractor sounding, ill screw around with my plates and if none of that works, maybe ill look for a different exhaust.
__________________
Old Nov 27, 2005 | 01:46 AM
Yeah just weld it into your I-Pipe. If I were you like you said. Put your LT's on play around with your plates. If you like the way it sounds then stick with it. If it's raspy then put the XR1 in the I-pipe and that will take care of it. I believe it's going to sound badass wit out the XR1
Old Nov 27, 2005 | 10:39 AM
Superman09's Avatar
LS1Tech Sponsor
Yea im sure it will be hella loud. So let me get this straight..... The I pipe is which pipe? And if i weld the XR1 in there, will i be running 2 mufflers than? Or if the stock borla muffler in the I pipe already and im jsut switching mufflers? Thanks!
__________________
Old Nov 27, 2005 | 03:16 PM
The I-pipe is the intermidiate pipe. The single pipe that runs from the Y-Pipe over the axle. If it is to loud and raspy. Just weld the XR1 in the I-pipe right before it goes over the axle. So yes you will have two BORLA muffler's in the system. The XR1 is very low restrictive. So it's not going to hurt your power to bad.
