Got done with exhaust install
I dunno i'll run it for a little bit, fix the banging and the leaks and see how it sounds.
ALSOOOOO you could try a 50 dollar spiral muffler from summitracing.com that would go on the Ipipe and reduce the rasp significantly if not completely. I know it's helped with mine. Cats are overrated anyways Good luck though bro
have to be a bad leak to really notice.
Leaking at header flanges is usually more of an annoying,
ticking kind of sound.
Also, out of curiosity, did you use the supplied (U) clamps
or use band clamps on the collectors/I pipe?
...and I agree with you on the emissions stuff. I was so
tired I actually tried to put the EGR tube on the AIR
pipe.
