need high flow cats
Old Dec 5, 2005 | 05:45 PM
hpjunky98's Avatar
Default need high flow cats
ive looked everywhere. where can i find some direct replacment high flow cats for an ls1 camaro?
Old Dec 5, 2005 | 06:35 PM
Redneck Z's Avatar
Magnaflow/carsound makes direct replacement cats. You can find them on e-bay or summit. Other places(not sponsers) sell them also.
Old Dec 5, 2005 | 06:37 PM
FUN LS1's Avatar
I got mine with my LTs at http://www.slponline.com/.
Old Dec 5, 2005 | 08:22 PM
Redneck Z's Avatar
I think he wants direct replacment cats for stock manifolds.
Old Dec 6, 2005 | 08:59 AM
jimmyblue's Avatar
Moderator
Interesting question but I think the answer is none.
Stock pup-cats are funky, one-off, small and bent.
You can't fit a bigger case in where they go and all
you could do for high flow, is make a less effective
(larger passages) "brick". I believe a metallic substrate
(like many aftermarket high flow cats) would get hurt
quick, that close in to the motor (overtemp threshold
has got to be lower).
Now, you can increase the flow mightily with your
friend Mr. Crowbar but they're going to be somewhat
less effective at saving the endangered speckled
tadpole, then. Even more so than "high flow" cats.
Old Dec 6, 2005 | 11:06 AM
Redneck Z's Avatar
I disagree....I have the magnaflow direct replacement cats, and they are very nice. They don't have a larger incasement than stock. They have almost twice the holes per square inch as the stock cats, and a much more fluid design. They are 50 state legal and made to pass emissions and last a long time. They fit, look and flow very well.
Old Dec 7, 2005 | 06:55 PM
hpjunky98's Avatar
is summit the only place that sells them?
Old Dec 7, 2005 | 07:11 PM
Redneck Z's Avatar
QUOTE:Magnaflow/carsound makes direct replacement cats. You can find them on e-bay or summit. Other places(not sponsers) sell them also.
Old Dec 7, 2005 | 07:23 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
In addition to Magnaflow, Random Tech used to make an entire replacement Y-pipe for stock manifolds that also included cats (in the stock location). Not sure if that piece is still sold, probably more expensive than the magnaflow option, but if you wanted a whole aftermarket Y-pipe including cats, that would be another option.
Old Dec 8, 2005 | 04:59 AM
300bhp/ton's Avatar
Two words:
Random Technology
Get the 7000 series Metal Matrix ones. They good for motors producing about 550bhp.
However, unless you are changing the headers and the mid pipe there really is no point in swapping the CATS over.
Old Dec 8, 2005 | 12:23 PM
Redneck Z's Avatar
Originally Posted by 300bhp/ton
Two words:
Random Technology
It depends on what you have done to your car, and what your future plans are. In my situation, there is a point, and gains to be had by swapping out the cats.
Old Dec 8, 2005 | 04:03 PM
TNMuscle's Avatar
magnaflow makes some nice ones so ive heard........
