Bumpstop Mod: my first try at writing an install
Old Dec 14, 2005 | 06:29 AM
slow trap's Avatar
i work at a machine shop so when i ported my tb i put it on a mill and cut it down a bit.i'm a lazy slob,that dremel sounds like work.great write up.
Old Dec 14, 2005 | 07:20 AM
RDeputy150's Avatar
Nice writeup. How bouta sticky mods?
Old Dec 14, 2005 | 11:36 AM
jimmy 2 Times's Avatar
hmmm, this is an intresting mod. Will this affect my tune, or will it set off any SES lights?
Old Dec 14, 2005 | 11:37 AM
btw,
excellent write up
Old Dec 14, 2005 | 12:32 PM
v8hunter's Avatar
Nice write up.
Makes my wonder if you can do it by measuring the resistance of the tps with the throttle body off the car...I would assume that the resistance of the tps causes the voltage to vary???
Does anyone know for sure and what to shoot for?
Old Dec 14, 2005 | 02:21 PM
MadBill's Avatar
I'm with Twister.
I've seen enough electronics issues on 'hundreds of parts-an-hour' build rate assemblies that I wouldn't think of trusting a mulitimeter reading over a measurement on the actual throttle blade...
Old Dec 14, 2005 | 04:17 PM
1BADTALS1's Avatar
as i said B4
this should be added to the sticky...
i will be doing this as soon as it warms up a bit..and the snow is gone so i can do a couple WOT runs after without haveing to worry bout the snow
Old Dec 14, 2005 | 04:48 PM
Z28Streetwimp's Avatar
Originally Posted by Twister
Just going to throw this out there.
Shouldn't some reference to the actual Throttle blade be made? Great write up btw. If my sensor is showing 95% throttle opening and my blades are WOT, shouldn't I then look for modifying the actual sensor itself instead of the blade opening?
I've heard that this is also an issue on some cars and you may need to slot your TPS and rotate it so that it actually reads 100% when the butterfly it at 90*, if not the ECM many not be commanding true full throttle fueling.
Old Dec 14, 2005 | 07:46 PM
Pewterpower's Avatar
Damn, yall got some seriously technical questions.
and thanks for props on the write up.
Old Dec 14, 2005 | 07:55 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
You folks are making this much too hard....
The TPS does not have to register 100%
to give full WOT fueling.....
...and I'll say again, there is no certain
voltage to shoot for. Get the TB blade at
a 90* angle and don't go -to- 4.75V.
This is an "old" mod, LOL, but a good one.
Concerns about the throttle cable not
moving far enough may be valid, although
I've never personally seen it.
Happy modding.
Edit to change the code set voltage.
Old Dec 14, 2005 | 08:09 PM
Couldn't have said it better.
As far as the cable goes, I did have some issues with that. After I got the blade to 90* (by pulling it back, by hand) I found that the cable (by stepping on the gas pedal) wasn't pulling it all the way back to the bumpstop. I had to mess around with the cable adjuster thing, and then take out as much slack as I could. I put some spacers on the cable where it attaches to the gas pedal. It was kinda a PITA cuz just when you think you got it perfect, you find that the blade isn't retracting all the way back to idle. And you're idling at 1000 rpm. So you go back to the drawing board.
Old Dec 14, 2005 | 08:41 PM
  #32
Ace$nyper's Avatar
Great write up and post!
Old Dec 15, 2005 | 03:37 AM
  #33
JustAnIlluzion's Avatar
Originally Posted by WS600rr
Has this made a noticible difference for you?
did u not read all the posts?
btw great writeup , i will do this come springtime
Old Dec 15, 2005 | 08:10 AM
  #34
Twister's Avatar
He is from Florida, give him a break! We are a little slow down here.
Old Dec 15, 2005 | 04:47 PM
  #35
Zymosis's Avatar
Pefect write up, you can feel it (throttle response), but as for dyno and track times, I'd assume no/little change.
This write up would have been useless without such good pics. I vote sticky even though we all know nobody reads them
Old Jun 9, 2006 | 06:47 PM
  #36
FireSilverLullaby's Avatar
I just did this mod today and went from 4.35 volts to 4.65. I could definitley tell a difference goin from 92% throttle to 98% throttle.
Old Jun 9, 2006 | 07:04 PM
  #37
Mike02Z's Avatar
Very nice write up but as someone said to me once "Your just trying to get a sticky"
The pictures are excellent.
Old Jun 28, 2006 | 07:56 PM
  #38
98SS1LWEE's Avatar
Did, it works great,thanks for the good article and how-to
Old Jun 28, 2006 | 10:25 PM
  #39
CJDZ24_Z28's Avatar
Going to do this when i wake up! Great write up and detailed pics! Big thumbs up
Old Aug 12, 2006 | 09:22 PM
  #40
02BEAST's Avatar
Wouldn't just having your TB ported by someone make the blade open wider?
