Bumpstop Mod: my first try at writing an install
Old Sep 7, 2006 | 04:30 PM
  #61
texinteg's Avatar
I will be doing this mod this weekend. along with porting the throttle body.
Old Sep 7, 2006 | 05:57 PM
  #62
WhiteStripes's Avatar
Well, the Voltmeter I bought is on crack, and doesn't have settings like that. On the DC volt check, it just sits there and randomly displays between 34 and 71 volts not even touching anything. Looks like I'm out 25 bucks.
Old Sep 8, 2006 | 12:54 AM
  #63
miamifan3413's Avatar
Did u make sure it was grounded good??? Mine did that when it wasn't grounded properly
Old Sep 8, 2006 | 03:50 PM
  #64
bjamick's Avatar
alright man great write up this needs to be stickied, im going to try this whenever i get the chance but i dont have a dremmel so guess il just use a file.
Old Sep 12, 2006 | 12:25 AM
  #65
fenix99's Avatar
Restricted User
a file...or dremel...or drill with some kind of decently strong grinding bit it can grab on to will work just fine...and like someone said be4 ig you go over the limit, tap the bump with a tapping bit...and put a screw in it..and adjust where you want the blade to stop like that instead of having to worry about where to stop grinding
Old Nov 7, 2006 | 10:33 PM
  #66
orange_eskimo's Avatar
did this mod tonight, worked pretty well but I cant tell a difference really, Im sure it helped some I just cant feel it but I go by the every little bit counts method.
For all you guys that accidentally go over, I just put some electical tape on the tab and that worked fine.
Also make sure that you check your reading the voltage with you pushing down the pedal from inside. My multimeter's cables were long enough that I could put mine on my windshield and read it from inside. Just using my hands I was getting a 4.69-4.70 reading, when I mashed the pedal to the floor (ie like at the track) I was getting 4.74-4.75 readings. I just slapped a couple layers of tape on the tab and that dropped it back down to 4.71-4.72.
Old Nov 7, 2006 | 10:43 PM
  #67
D_Rock's Avatar
This seems like something that is to good to be true. But hey who the hell cares if you guys can feel the difference then it must yield some kind of gains.
Old Nov 7, 2006 | 11:37 PM
  #68
71-Camaro-98's Avatar
I dont know if someone asked this already, but what did you have the Multimeter set to when you were talking the voltage??
Old Nov 8, 2006 | 09:07 AM
  #69
Zymosis's Avatar
Volts DC, the 20 scale.
Old Nov 1, 2007 | 09:11 AM
  #70
Bad Blue WS6's Avatar
anyway someone could bring these pics to life? I can only see lil red X's
Old Nov 1, 2007 | 02:02 PM
  #71
radz282003's Avatar
This is a great write-up! I think I have to redo mine to make sure I clearanced it enough. Great job!!!
Old Nov 11, 2007 | 01:17 PM
  #72
Pewterpower's Avatar
Pics are fixed. I moved alot of stuff to another hard drive and it affected my photobucket addys and all that good stuff. Glad to see alot of folks still checking this thread!
Old Nov 11, 2007 | 07:19 PM
  #73
01ssreda4's Avatar
but are all years the same max limit voltage? mine is a 2001 and i would want to be sure i would not be going too far bc of not knowing what full throttle voltage is for that year.
Old Jan 1, 2008 | 06:17 PM
  #74
01ssreda4's Avatar
any takers?
Old Apr 7, 2008 | 07:23 PM
  #75
EndlessSummer85's Avatar
Something you should add to this is the voltage before you do the bump stop mod. I know mine was crazy low, it was at like 2.9 volts!!
Old Apr 8, 2008 | 07:07 AM
  #76
dragcamaro's Avatar
would it be safe to use a scanner with live data that has the actual angle? im pretty sure it has voltage too, i just wanted to make sure i wasnt going to screw it up computer wise if i did it this way
Old Apr 8, 2008 | 08:09 AM
  #77
DarkJuggalo's Avatar
heh imma have to try this
Old Apr 10, 2008 | 07:27 AM
  #78
Dave 96TA's Avatar
I checked mine, it was 4.65 stock so I left it alone.
Old Apr 10, 2008 | 02:36 PM
  #79
Alt's Avatar
Alt
Its amazing how many people swear by this mod when I can't even get the TB to open all the way without taking the carpet out of my car so removing a stop I don't hit is worthless. So you take that and add in the fact that flow though a "valve" such as a throttle body is measured with square root extraction. So say you can only open your throttle body 81%, measuring flow you are flowing 90% of what that TB can do wide open. Only opens 90%? Well then you're at 95% flow, to me I find the bumpstop mod to be almost negligible. Hell, I couldn't even use it anyway w/o cutting away at my floorboard or shortening my cable.
[\rant]
Old Jun 5, 2008 | 04:51 PM
  #80
NeXuS's Avatar
Exclamation
well i just did this mod bought a 2.99 multimeter from harbor freight and 1.99 for a hand file... it took a little longer with the hand file but im spot on at 4.71 Dead Nutz... But i did notice that when i put the peddle to the floor i was only maxing 4.52 if you look right in front of the battery there a small black half cylinder looking thing with 3 wires running to it i believe its your cruise control. Pop the top and you will see the wire house on the very bottom theres a small piece of green rubber like a bump stomp that prevents you from going WOT just take a flat head and pop that little sucker out of there now you can go WOT as far as the bumpstop on the TB will allow!!! Hope this helps you out Alt and any others that have this problem Sorry i dont have any pics to post but if you just look you will find it...
